Old 03-01-13, 01:56 PM   #1
JonGeorge
Default Choke stuck on.
Hi all..
The curvy has been stood for 4 weeks and this morning I went to use it for work, Noticed the choke lever was a bit stiff, started it up etc etc went to move the lever back and it moved easy enough but the choke is still applied? Does the cable need a grease? or something more sinister..also I had to ride the bike does it matter?
cheers
Old 03-01-13, 02:02 PM   #2
Lawman
Default Re: Choke
Sounds like the cable is stuck, lift the tank, take off the air box and sort it at both ends with a bit of light oil.
Old 03-01-13, 02:12 PM   #3
JonGeorge
Default Re: Choke
Ok thanks, is that where the cable splits to the 2 carbs?
Old 03-01-13, 02:12 PM   #4
Biker Biggles
Biker Biggles's Avatar
Default Re: Choke
And while you are under there do the choke plungers on the cabs as well.They may or may not be the problem this time but soon will be if not maintained regularly.
Old 04-01-13, 09:00 AM   #5
Sir Trev
Sir Trev's Avatar
Default Re: Choke
This
Had the same problem on my curvy with the sticking cable. Dripping oil down made it a bit better but after a while it made more sense to replace the cable (it's not expensive). Beware of the plunger retaining screws as they're made of cheese - I cheated with mine and had Spannerman do them along with the cable during a service.
Old 08-01-13, 01:54 PM   #6
mep
mep's Avatar
Default Re: Choke
Originally Posted by Sir Trev View Post
This
+1 do this. It is worth it in the long run. Do it soon before your plugs foul up as well.
mep is offline   Reply With Quote
Old 08-01-13, 05:00 PM   #7
rocklicker
Default Re: Choke stuck on.
Same issue with mine this morning and the bike hunts at idle between 1000-1300 so it looks like a Sunday full of scrapped knuckles, potential burred screw heads and general swearing.
Will riding short term with the hunting at idle cause any further problems in terms of mixture?
Running poorly - carb stuck on choke. emc_andy SV Talk, Tuning & Tweaking 5 31-12-11 04:24 PM
Help please - CD stuck in car!! Messie Idle Banter 15 02-12-11 01:13 AM
Stuck Choke Cable Milky Bar Kid SV Talk, Tuning & Tweaking 20 11-03-11 05:22 PM
Stuck Choke Plunger 2000curvy SV Talk, Tuning & Tweaking 8 14-12-10 06:58 PM
Running an engine with a stuck choke Caddy2000 SV Talk, Tuning & Tweaking 11 31-08-07 02:36 PM
