Old 07-01-13, 04:42 PM   #1
Brettus
Default Tripods and airports
Afternoon all,
I've got another work's trip to Gent next week and the place is so stunning I want to take my camera this time, I also need a tripod.
iPhone pic from last time:
https://pbs.twimg.com/media/BAAH1onCMAEfwWY.jpg:large
I've got a very nice tripod but I'm not sure how airport security will react to it, has anyone done this?
Or does anyone have any suggestions for alternatives? I've looked at Gorillapods and I'm just not convinced by their strength, I've seen the beanbag ones too, but I'd like someone thats actually used them to recommend.
Any thoughts/comments greatly appreciated as always
Old 07-01-13, 04:49 PM   #2
tigersaw
tigersaw's Avatar
Default Re: Tripods and airports
It should be fine as hold luggage.
Hand luggage, it may depend on both the airports and airlines policies. I can ask regarding the airport bit if you like.
Old 07-01-13, 05:07 PM   #3
Littlepeahead
Littlepeahead's Avatar
http://www.amazon.co.uk/gp/aw/d/B002...7578222&sr=8-1
I took one of these to Thailand as hand luggage. I needed a stick to walk so it was handy taking low light pictures.
Old 08-01-13, 08:25 AM   #4
Sir Trev
Sir Trev's Avatar
I've use the flexi-leg-type mini tripods to good effect but only on a compact. You also need to be lucky with something of a suitable height to stand it on unless you're going for a near-the-ground shot.
Old 08-01-13, 09:26 AM   #5
Brettus
Hmm, thanks for the input everyone, I'm stuck with either put it in the hold (£30 return I think) or get a mini tripod/gorillapod and take my chances with something to perch it on.
LPH: I've got a monopod but I suspect they will still take umbrance at the fact its a pole shaped object that I can access at any time (or others could, more to the point I think) plus I'm wanting to take nighttime HDR which will likely need 30sec exposures for the lighter exposure so I'd need to brace it against something so I'd still be stuck with a work around
Getting through security unmolested seems to be hit and miss even without anything contentious. Knowing my luck I'd get someone on the end of the shift after a bad day. I'm travelling with a group too so I don't wanna get too much hassle/delay.
I'd even considered this:
YouTube Video
but with the length of exposures I'd still get movement which would ruin it.
given my constraints I guess my only option is to check it in if I don't want to change what I want to shoot.
Old 08-01-13, 12:04 PM   #6
Littlepeahead
The great thing about that monopod is that it's a walking stick so they don't seem to question it - maybe walk with a limp s you arrive at check in!
The alternative as you say is a gorillapod. I have a titchy one I use for my compact but they now make several heavy duty versions for DSLR and Pro DSLR with zoom and they look the business, you just have to find a suitable bar or flat surface. I used my little one to take this pic at Windsor the other day wrapping it around a crash barrier and then setting the timer. Even the pro one would fit easily in hand luggage. They are pretty good.
Might be cheaper just to buy a cheap and cheerful tripod out there and then see if you can sneak it back and if not then bin it at the airport.
http://www.wexphotographic.com/buy-j...fxhltaodtvoa5w
Old 09-01-13, 09:39 AM   #7
Brettus
I've taken the plunge and booked a bag in, I'll take it through that way. do the trip properly, if I was going to be going to many other places I'd likely invest in a portable solution but it is likely just to be this trip for the foreseeable future so I'm taking the proper job.
I just hope my shooting skills do justice to my expectations.
Also the weather, hope that holds nice!
Old 09-01-13, 10:56 PM   #8
Richie
fantabulas
Richie's Avatar
that string, washer & bolt steady trick looks quite good.
Cheers for the tip matey boy
My Flickr photos
Old 19-01-13, 09:38 AM   #9
Brettus
Morning all, I don't want to start a new thread for this as I spam you guys enough already when I get photographically enthused.
Here is the gallery of pics I took on this trip:
Probably the best view for each:
http://www.flickr.com/photos/brettne...2996/lightbox/
List view:
http://www.flickr.com/photos/brettne...272996/detail/
On a map:
http://www.flickr.com/photos/brettne...556272996/map/
IMHO well worth the €15 to book the bag in (only had to pay one way as it was included in the Brussels air ticket)
