Old 07-01-13, 07:34 PM   #1
Default Mixed bag of bits for modded SVs
(first of all- hello .org! I ain't dead)
The mighty garage clearout's turfed up about 40 tons of scrap metal, and a tiny pile of things that might be of use to someone. Here is most of it. Prices are fairly rough, if anything seems excessive let me know, open to sensible offers.
A set of used stainless bolts, were fitted to a curvy but will fit others. These were on the bike for quite a long time so they have some marking etc but are still good, and much nicer than scabby OEM ones. Either Probolt or Aerotek. I guess £20 posted?
Some radial brake calipers, for the GSXR swappists.
These are all used but in decent nick- the black is a little faded from road use. They all have pads fitted but I can't guarantee they're still good- they were, and were all used on my bike but they've been in storage for years so might have picked up contamination. Should be OK though.
The 2 Tokicos are off a GSXR of some description, I think a K6 750 but they're widely interchanged. They come with stainless bleed nipples. They're the slightly taller ones, so may not work with certain smaller GSXR discs or combos of forks- I used them with GSXR750 K4 forks and 320mm GSXR discs and possibly 10mm spacers on each, but that was ages ago so not 100% about the spacers
These seem to be about £90 on ebay for a pair, but I just want them off to a good home so would do £50 posted.
The Yamaha one is a left hander, and has no hardware, but does come with discs. Now for fitting, this one has a sticky-out sleeve on the mating face, which isn't directly compatible with GSXR forks (essentially radials are either male or female, on GSXRs the forks are male and the calipers are female, this is a male caliper too) So you need to either remove it, or (like I did) use an intermediate spacer. So, it's kind of up to you to work that out. I still have the other one on my bike, with a spacer, the above K4 forks and a 330mm disc.
Ebay says £65 each, let's go for £40 posted- but do be careful with these ones, you'll need to suss out the fitting.
Spare Ktech spring, was fitted to my Ohlins but was a bit too stiff for me. In good nick but some marks in the yellow. This is a 105N spring (full spec is 57/160/105)
Eh, let's say £30 posted.
A Harris steering damper mount- you're on your own with this one, I never fitted it! Allegedly off a SRAD GSXR750. Free to a good home as you'll need to find a suitable upright arm for it and a damper of course. Shame to bin it!
GSXR front end stuff-
This is a pair of TL1000 clipons, which are a bit higher than the standard GSXR ones so comfier. I used these for ages but eventually fitted higher (and tartier!) LSL ones.
Also a GSXR 750 SRAD top yoke- perfect for your curvy conversion needs. Again off my bike, but was replaced with a Vortex one for reasons I can't even remember now. Tartier? Yeah probably.
I haven't a clue what these are worth- make me an offer
Old 09-01-13, 08:02 PM   #2
Default Re: Mixed bag of bits for modded SVs
Tokico calipers sold, cheers!
Old 10-01-13, 02:10 PM   #3
sheepracer
I'll take the spring if it fits a standard curvy shock??
Old 10-01-13, 07:35 PM   #4
I don't honestly know if it does (don't have one to compare) but it'd be a fair bit stiffer so I reckon it'd absolutely knacker the rebound. I think I'd have to say it'd make more sense to replace the whole shock...
Old 18-01-13, 09:57 AM   #5
FOO
Hi,
How much for just the r6 caliper?
Best Regards
Foo
Old 18-01-13, 03:03 PM   #6
Hi, was looking for £40 posted- probably worth a bit more but this saves me reviving my logons for other forums where R6 owners live
Old 18-01-13, 06:54 PM   #7
FOO
Hi,
I can currently stretch to £35, if any good?
Foo
Old 19-01-13, 12:57 AM   #8
It'l might be expensive to post- I'll get a quote and get back to you.
Old 19-01-13, 06:10 AM   #9
FOO
Hi thanks for looking into it
if you can do it for £35 all in i will pay straight away
Cheers Foo
Old 20-01-13, 05:43 PM   #10
lawson17
What would you be asking for the TL clip ons northwind?
My finished modded k5 sv! tayto94 Bikes - Talk & Issues 22 19-12-09 04:29 PM
curvy front end modded? Svkid SV Talk, Tuning & Tweaking 7 28-02-08 11:03 PM
My modded k5 (Video) Bornagainbiker Photos 6 02-01-07 09:23 AM
My modded SK6 2pot-thumper Photos 10 27-08-06 02:13 PM
saw a really nice modded car today Warren Idle Banter 6 13-08-06 10:14 AM
