Old 25-01-13, 07:38 PM   #1
DanSp
Smile Track Preperation?
Hi all... Ive decided to keep hold of the curvy i purchased a few weeks back and am going to put it on track for a bit of a play... The only bits ive sold so far are non essentials or cheap enough to replace.
Needs a good full service including complete brake overhaul.
The fairings (bikini) are all slightly damaged so im currently unsure whether to just leave it as it is, or search for a track fairing, anyone have any ideas how much i would be paying for a second hand one!?
Any other hints/tips for me to do to the bike? ill probably be looking for my first outing to be about april/may time so i have time to tinker (and save up)
Old 25-01-13, 08:27 PM   #2
Redmist
Default Re: Track Preperation
The usual tips I guess, loose as much weight as poss, upgrade whatever useful bits you can afford.
Depends on your budget, I quickly blew thru mine so I guess decide on that first!
Old 25-01-13, 09:31 PM   #3
phil24_7
I wouldn't spend any money that doesn't need to be spent. You may find your not a fan of track riding or your financial situation may change. Sort the brakes and then remove all the breakables and things you don't need like: Lights & rear footrests, then just tape over the light holes. If you like it and are planning on doing 2 or 3 a year then look at throwing some money at it.
Regards
Old 26-01-13, 08:33 PM   #4
jambo
jambo's Avatar
Good advice.
Loose weight. The track bike I helped build has nothing forward of the head stock, no plastics, instruments, sub-frame, nothing.
Simplify the wiring loom, loose the excess off the rear sub-frame, ditch the radiator fan, it all adds up and doesn't cost a penny.
Fit decent fast road tyres, make sure the brakes are in good condition, and fit a zx6/gsxr/after market shock.
Fit crash mushrooms.
You should now be ready to rock and roll.
Jambo
Old 26-01-13, 09:06 PM   #5
L3nny
L3nny's Avatar
Only thing I'd recommend spending money on are some wets on wheels in case we have another wash out summer. If your a track day novice even a stock curvy will be more than enough to have fun on.
2015 GS 1200 Adventure
Old 26-01-13, 10:18 PM   #6
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: Track Preperation?
Like what's been said, tyre's. My last trackday was a bit meh because of the naff tyre's i was running.
weight is probably a good one aswell, if you get a good day weather/track temp wise you'll be knackard by lunch time, i usually am.... And then stupidly i go a feed my face and am even slower from being stuffed.
05 DRZ400E
RIP hovis
FS: Yamaha FZ600 Track bike. Bargain first track bike! NC24 For Sale - Other Bikes and General biking items 1 29-10-10 02:59 PM
track day at teeside karting track -18th june nik_nunez Pennine Massive 8 03-06-10 03:23 PM
Name your all time favourite Track Day track. Tim in Belgium Track Days 11 28-11-08 11:56 AM
If you had to choose one track to be the title track to the film of your life.... Paul the 6th Idle Banter 5 09-10-08 06:27 PM
Fairing Spray Preperation? sprocket Bodywork 11 05-04-06 05:51 PM
