Old 25-01-13, 11:13 PM   #1
rivsm
Default BYPass Alarm Help Please
Hi guys n gals
I have a 2000 sv 650 curvy with a Meta 347 T V2 alarm. After the snow had settled on the bike and began melting I assume some water shorted the alarm as now if I try and de activate the alarm, nothing happens. If I turn the key all the lights on the bike display come on but the bike refuses to start. I think I need to bypass the alarm but havent the faintest idea how to do so. I need the bike for work urgently. Any help will be greatly appreciated.
Thanks in advance.
Rivsm
Old 25-01-13, 11:44 PM   #2
rivsm
Default Re: BYPass Alarm Help Please
Any Help pls
Old 25-01-13, 11:48 PM   #3
Wildkid
This is why I dont have an alarm!
Old 26-01-13, 08:14 AM   #4
rivsm
Guys any suggestions pls. Sorry to harp on but I need my bike up n running asap pls
Old 26-01-13, 08:35 AM   #5
DJ123
DJ123's Avatar
Obviously it isnt easy to do, otherwise the alarm would be pretty useless. Do you know if the alarm is also an ignition immobiliser?
BMW F800ST
Old 26-01-13, 08:36 AM   #6
joshwalker094
joshwalker094's Avatar
Have you checked the kill switch?
If the alarm wasn't working then surely when you turn the ignition on it would go off?
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 26-01-13, 09:26 AM   #7
suzukigt380paul
no! once youve disconnected one alarm there all fairly simple to take off,the biggest job may be getting to the wires,after taking my alarm off my bandit i can tell you there is nothing to it,
find the alarm,normally under seat take any alarm connectors off,follow the wires and cut or disconect at any junction(live wire feed,indicators
,linkwire,red flashing light,etc) with the wiring harness,and there may well be a few wires you take off that have to be linked back to gether(link wire)this normally breaks the connection to the coils so the engine cant be started but may still turn over,no 2 alarms are the same mind you,but if you no where the link wire is you could start a alarmed bike in seconds even with the alarm sounding
Old 26-01-13, 10:42 AM   #8
Redmist
I removed almost the exact same one from my pointy SV, I found this video very helpful:
http://www.youtube.com/watch?v=aj1GqwJBDmw
Once you've removed enough insulation from around the wiring loom, working out what needs to be spliced back together is pretty easy. Most of the wires are to make the indicators flash so you can simply cut them off.
Then there was about 3 connections to sort out. Starter relay wire, simply join it back together.
Then I had to re-join a link to join two orange wires back together.
A Haynes manual made much easier with the wiring diagrams it includes.
Old 26-01-13, 10:49 AM   #9
You got soldering iron and heat shrink?
Old 26-01-13, 06:39 PM   #10
phil24_7
You checked the battery in the key fob?
Wooton Bassett bypass? punyXpress Idle Banter 4 12-12-10 04:31 PM
Oil pressure bypass valve. ThEGr33k Bikes - Talk & Issues 23 17-07-09 11:49 AM
Eyeball - Beverley Bypass DarrenChay Pennine Massive 0 22-04-09 09:07 PM
Was that you on the A1 western bypass? toonyank Bikes - Talk & Issues 1 05-06-07 10:36 PM
Eyeball Hayes Bypass FG1 Idle Banter 0 16-10-06 08:19 PM
