Old 29-01-13, 04:10 PM   #1
2087
Default curvy brake caliper reinstall not going well
Folks,
Took both calipers off my 650 SX, stripped one, rebuild with new seals etc, ready for install. The second one the pistons are jammed, it was my intention to refit the complete caliper, and the skeleton of the second, bleed the system and use hydraulics to push the stuck pistons out.
For some reason when I tried this today, the lever would not go firm (the technical term haha). It was like no fluid was getting through to enable a bleed. There was fluid getting into the caliper as fluid was trickling out of the bleed nipple, but no pressure.
Anyone any ideas? Its probably something really simple I am missing, but am just off the night shift so not all of my cylinders are firing.
Gary.
Oh, also noticed that only one of the calipers has the brake line guide bit, this is normal..?
Old 29-01-13, 04:12 PM   #2
Default Re: curvy brake caliper reinstall not going well
Air stuck in banjo bolt somewhere, fiddle with it to remove high points and allow bleed. Then bleed out of banjo bolts themselves.
Especially bad on S bikes... M/C points uphill. And on stock brake lines with 1-2 splitter thing on bottom yoke.
Old 29-01-13, 04:17 PM   #3
2087
Think I got you dude, cheers for reply.
Just so I am sure what you mean, effectively the 2 holes in the banjo bolt itself have to be in line with the travel of the brake hose? Ill mark the bolt if that is the case and line it up
Might have to semi rebuild other caliper, going to be a PITA to do this when it hanging off the flexi lol
Old 29-01-13, 04:20 PM   #4
no no just tighten them correctly, if you try to line holes up they will end up either mullered or loose.
Never mind ports inside bolt.... for master cylinder bolt bleed, I just lean bike to left. This allows air in bolt to run up into reservoir.
Old 29-01-13, 04:32 PM   #5
2087
Cool, its on the side stand anyways so is leaning left, Ill have a wee play about with bike try force air out.
Old 29-01-13, 08:00 PM   #6
I'd used a big syringe connected to some clear tubing and sucked the hydraulic fluid through on mine. Managed to get it pretty good and then got the rest of the air out of system in the usual way.
Curvy brake caliper seals - where from? bmack999 SV Talk, Tuning & Tweaking 2 09-10-12 07:20 PM
Curvy rear brake caliper husky03 For Sale - SV's and SV related items 28 15-09-10 08:56 PM
Rear curvy brake caliper beabert Stuff Wanted 9 07-02-10 10:43 AM
Curvy front L & R brake caliper Lucas For Sale - SV's and SV related items 4 03-02-10 11:28 AM
Rear brake caliper for a curvy captainsmelly Stuff Wanted 4 09-07-09 04:59 PM
