Old 31-01-13, 10:10 AM   #1
JonGeorge
Question Removing brake pistons?
Hi,
Is there anyway I can remove the pistons without using the bikes hydraulic system or compressed air, as I have neither here with me?
cheers
Old 31-01-13, 10:26 AM   #2
Runako
Default Re: Caliper pistons
If there is a bit of the piston protruding you can pull it out but the most important thing is not to damage the piston surface in any way. So padding or cloth around the teeth of pliers is one technique which has been used (emphasis on taking it very slowly so as not to damage piston). Otherwise put the piston back on the bike (or any connected brake line that takes the banjo). Might be longer and more frustrating but you're unlikely to damage the pistons.
Edit: never tried it myself but don't see any reason why you couldn't attach caliper to the rear brake as the banjo should be the same size. This is assuming the calipers are for the front and that you can't use the hydraulic system because you've released the fluid from the system.
Old 31-01-13, 10:50 AM   #3
Dicky Ticker
Default Re: Removing brake pistons?
Suggestion- two pieces of wood on the floor,place the split caliper with the piston in the space clear of the floor, and tap it with a rubber mallet so that the piston can vibrate free.
Simple but can be effective in many cases.
Old 31-01-13, 11:42 AM   #4
JonGeorge
Ok, went and got some brake fluid, used the hydraulics on the bike and only 1 piston came out? What nhow
Old 31-01-13, 11:51 AM   #5
ehhsee
I have this exact same problem, just stripped the front brake, and all 4 pistons are stuck, can't use the hydraulics and I have no access to a compressor.
Any more advice? :L
Old 31-01-13, 11:53 AM   #6
JonGeorge
I've managed to get one out, but the other wont budge....I'm fooked
Old 31-01-13, 11:59 AM   #7
dirtydog
Knob faced knobster
dirtydog's Avatar
If only one is moving put a g clamp on the one that's moving then the other piston should receive all the pressure and start to come out when you pump the brake lever
2011 Speed Triple 1050
Old 31-01-13, 12:00 PM   #8
Runako
No, you're not. Put the good piston back in and secure it in some way so that it wont move. This should provide more pressure for the one that is stuck. It only needs to move little by little. If you can see any residue or debris around the piston then clean it. i don't know if soaking it in brake fluid or WD40 or similar might help but it may be worth a shot. Then do the above and it should get it moving. Remember, if you don't get a strong lever then there's probably air in the system, so try and blled all the air out to get a stronger pressure. Your pistons would have to be ancient to be stuck beyond removal using the normal method.
Old 31-01-13, 12:00 PM   #9
JonGeorge
Tried that, cant gain pressure again
Old 31-01-13, 12:01 PM   #10
JonGeorge
I can't seem to get the air out
SV650K3 Brake Pistons - where do you get yours? Longway Bikes - Talk & Issues 2 17-01-12 06:55 AM
Best way to clean up brake pistons? curium SV Talk, Tuning & Tweaking 12 06-04-09 09:42 PM
Brake Pistons? vardypeeps SV Talk, Tuning & Tweaking 4 29-08-08 12:12 PM
scaring on brake pistons huge SV Talk, Tuning & Tweaking 2 13-01-06 04:32 PM
new brake pistons and seals. where from? raymond smith SV Talk, Tuning & Tweaking 2 30-04-05 09:24 PM
