Old 01-02-13, 04:24 PM   #1
Default Too many wires to my battery terminals
So. Remind me .. what is the thing I need to have all my ancillaries wired to my battery neatly..its a bit crazy under there at moment. 5 extra neutrals coming in . 3 live ..
Old 01-02-13, 04:28 PM   #2
Owenski
Default Re: Too many wires to my battery terminals
Get your self a terminal bus before the battery, you can hide it somewhere neat then take the single connector on.
I'm a sucker for it, I've got to have neatly neatly wiring.
Old 01-02-13, 07:28 PM   #3
85jas
Bibio's your man there Neat & tidy 3-way relay switched fuse box thingy, sorted.
Old 01-02-13, 07:40 PM   #4
Yes, but not for Quiff's VFR
Old 01-02-13, 08:14 PM   #5
phil24_7
Quiff, contact Bibio has he has a couple of options depending on what your running.
Old 01-02-13, 09:51 PM   #6
suzukigt380paul
if like me you have a mottobatt battery fitted then you have 2 pairs of terminals,so plenty of room for the wires
Old 02-02-13, 10:04 AM   #7
Dicky Ticker
In the past where I have been in a situation like that I have used a junction box. One heavy earth wire and live feed in and available with 7-9-12 exit feeds.Available from most caravan or good motor factors and the are waterproof.Use two core cable as required for your exit feeds.
Smaller boxes are available if you only need a few exit feeds.This way you only have the bike leads and two extra connected to the battery making a tidy fitting with ring tab connectors so easy to remove if necessary and all the other connections in the box and waterproof.
Old 02-02-13, 11:03 AM   #8
You can even be fancy and put the ring terminals on the live to starter relay rather than battery itself... only one connector on battery then.
Old 02-02-13, 03:27 PM   #9
I have a few things hard wired in to the switch live.. heated grips,autocomm,mandys rear heated grips but still have a couple of cig lighter sockets and stuff just wired direct..
presently though my battery will charge up.. but its not holding the charge ..
I guess its a PITA to find out why ..? before buying a new battery ... something is draining it when its sat still.
Old 02-02-13, 03:32 PM   #10
Disconnect it and see if it cures it. Could jsut be a naffed battery.
Wires and Electrics robc76 Mini-Twins 16 20-12-10 09:55 AM
Ring Terminals - battery connections. 5hort5 SV Talk, Tuning & Tweaking 5 04-03-10 04:34 PM
indecater wires hovis SV Talk, Tuning & Tweaking 4 24-09-06 11:40 AM
2nd/3rd wires andy owen SV Talk, Tuning & Tweaking 1 29-01-06 05:08 PM
chafing wires philb SV Talk, Tuning & Tweaking 3 13-06-05 06:34 AM
