Old 18-02-13, 10:25 AM   #1
muzikill
muzikill's Avatar
Default Suzuki part of the month - battery
FYI
http://www.suzuki-gb.co.uk/partofthemonth/
Suzuki Bike of the Month DJ123 Bikes - Talk & Issues 10 19-11-12 07:06 AM
VStrom 650 is Bike of the Month at Suzuki, huge savings on parts prices! Taipan SV Talk, Tuning & Tweaking 7 21-02-12 04:47 PM
Suzuki bike of the month Bibio Bikes - Talk & Issues 6 04-08-11 11:31 AM
Curvy is bike of the month on Suzuki website Brettus SV Talk, Tuning & Tweaking 9 24-09-10 09:13 AM
Suzuki Bike of the Month Curvy SV650 September only andrewsmith Bikes - Talk & Issues 13 09-09-10 10:47 AM
