Old 19-02-13, 06:53 AM   #1
agy
Default Patching up plastics - how?
Out of curiosity. Is it possible or do you just have to get a whole new panel?
Old 19-02-13, 07:05 AM   #2
NTECUK
NTECUK's Avatar
Default Re: patching up plastics
Not nesaserily.
Been a few threads on hear dealing with it.
Try the serch function.
Old 19-02-13, 07:56 AM   #3
Wideboy
Evel Knievel
Wideboy's Avatar
What do you mean by patching up? Repairing damage? No its impossible to fix with plastic welding or some specialist glues.
Painting? it depends on the colour and the damages proximity to things like stickers ect and equipment you are using. Some colours will match up quite well and others won't. For example if you mask off an area and spray up to it there will be a masking line visible once the tapes removed which 90% of the time doesn't blend back in properly.
As said, loads of threads and If you're expecting a professional finish then take it to a professional.
05 DRZ400E
RIP hovis
Old 19-02-13, 08:28 AM   #4
NTECUK
NTECUK's Avatar
You can also vinyl wrap panels as an alternative to paint.
pic of what you want fixing be handy .
Old 19-02-13, 08:48 AM   #5
agy
Paint. The edge side on the front panel that takes the hit when you come off. It's light metallic blue
It's not bad. It's been like this for ages now. Certainly doesn't warrant buying new plastics but if I could cover it that would be a bonus
Old 19-02-13, 08:49 AM   #6
agy
I'll post a pic later
Old 19-02-13, 08:50 AM   #7
Dicky Ticker
In a word Yes--------I normally reinforce the damaged area at the back with fibreglass and resin before starting to work on the visible damaged area. Depending on what repair is necessary, but this usually requires cleaning before hand,rub or grind out chipped scored areas,fill and build up with fibreglass resin and finish with the gelcoat that they use on boats and then rub down by hand,prime and paint. I would do the whole panel in regard to painting and get new decals if required.
I go to a reputable commercial paint supplier who mixes on the premises with the relevant paint codes and take a panel that he can match it to. If you don't have spraying facilities they can supply the paint in aerosols---primer,paint and lacquer
IT IS NOT ADVISABLE TO PAINT IN COLD CONDITIONS so if you are doing this outside wait for warmer weather [+15c]
Old 19-02-13, 09:19 AM   #8
Wideboy
Evel Knievel
Wideboy's Avatar
If its metallic then do the whole panel
05 DRZ400E
RIP hovis
Old 19-02-13, 09:32 AM   #9
NTECUK
NTECUK's Avatar
Default Re: Patching up plastics - how?
It might lend it self to fix the damage and paint or apply a contrasting stripe to save painting the complete panel .
Old 19-02-13, 09:43 AM   #10
Dicky Ticker
If you are only talking about bikini fairing panel scuffs and scratches try and do it on the bike providing it is in the correct position and still properly attatched. Reason I say this is their are some plastic securing/positioning lugs inside which tend to get broken off on any frontal or side impact and you will not know they are broken till you remove the front.
BB Plastics Jack R1 Mini-Twins 1 01-11-11 07:55 PM
MiniTwin plastics lawson17 For Sale - SV's and SV related items 8 12-10-11 06:28 PM
patching into a switched power curcuit doser SV Talk, Tuning & Tweaking 6 17-08-11 04:12 AM
plastics rictus01 Bikes - Talk & Issues 7 09-02-09 04:16 AM
Will K3 Plastics fit a K4? Luckypants SV Talk, Tuning & Tweaking 4 20-01-09 10:59 PM
