Old 24-02-13, 01:43 PM   #1
sv650kent
Default No brake lights - Pointy.
Was out cleaning the sv650 2007 ready for the weekly commute into london.
I did the lights check and noticed that even though the rear lights worked when the brakes are pushed they do not change to show the brakes are on.
I checked out the wiring and all seems fine. My knowledge of the electronics are not to great can anyone help as i do not have a manual for the bike.
John
Old 24-02-13, 01:46 PM   #2
DJ123
DJ123's Avatar
Default Re: brake light issue
Which lever, front or back? or did this occur on both?
BMW F800ST
Old 24-02-13, 02:25 PM   #3
sv650kent
Sorry, happening on both front lever and rear foot.
Old 24-02-13, 03:43 PM   #4
Default Re: No brake lights - Pointy.
Does everything else electrical work properly? If no check fuses. If yes, pull the wires off the front switch and short them, does the brake light come on? If yes, then both switches are duffed*, if no, then make sure there's a live at both switch connections. If yes, check the rear light connector under the pillion seat - typically it's cable tied to the left frame rail, it's a white three pin connector. Do all three wires seem OK? Check along the wire from the connector to the light unit, any damage? At the loom side of the connector check that one wire is neutral, one is live all the time the ignition is on, (back light), and one comes live when either brake is pulled, if that's the case then the rear light or wire thereof is faulty.
*Believe me, it's rather more common than you might think. Obviously it's most unlikely that they'd fail at the same time, but one failing often goes unnoticed - if one works the light comes on and no one runs in to the back of you, often it's only when the second fails that it becomes apparent.
Old 27-02-13, 02:48 PM   #5
sv650kent
after playing around for ages i noticed that the rear light was brighter then i remember so i had a play and realised that the brake light was perm stuck on. it seems to be crap from the road had got stuck in the foot pedal and caused it to stick
panic over until next issue
thank you for all the advise, without the forum i would be stuck and pay over the odds for garage fees, so cheers lads/ladies
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
3rd brake lights? Nobbylad Bikes - Talk & Issues 6 07-06-09 03:58 AM
brake lights sticking on evertheoptimist SV Talk, Tuning & Tweaking 18 30-03-09 01:17 PM
New brake lights on an old SV? JDH SV Talk, Tuning & Tweaking 5 13-05-08 06:45 AM
indicators in brake lights dazzap Bikes - Talk & Issues 6 02-10-06 01:49 PM
