Old 28-02-13, 11:10 AM   #1
wolf89
Default Which chain and sprocket kit?
ok so i know this topic probably been covered but ive not eaten in 4 days due to illness so forgive my lack of searching i just cba atm. i have a 2001 faired suzuki sv650 failed mot on chain and sprockets so what i need is a new set for ideally under 100 can anyone reccomend me one?
thanks for your patience
Old 28-02-13, 11:17 AM   #2
jambo
jambo's Avatar
Default Re: Chain and sprocket
If you're not feeling your best look for kits from somewhere like this:
http://www.bandcexpress.co.uk/
http://www.wemoto.com/
Be aware the SV650S (faired) uses a different rear sprocket size (44 vs 45) and chain length than the unfaired SV650.
Make sure the chain is an o-ring or x-ring (rather than unsealed) and I'd recommend steel sprockets rather than alloy for longevity on the road.
Factor in the cost of having a garage fit it as it'll need a rivet link tool to do this which will cost a fair bit for a once only use.
Jambo
Standard front sprocket, bigger rear sprocket, how many more links in chain required? Holdup Bikes - Talk & Issues 6 27-02-12 12:40 PM
chain and sprocket kit bagger247 For Sale - SV's and SV related items 3 12-01-12 12:38 PM
520 chain on 525 sprocket YvenelC SV Talk, Tuning & Tweaking 2 26-12-11 07:36 AM
520 Sprocket and chain Hefyn18 SV Talk, Tuning & Tweaking 1 04-03-11 06:33 PM
Chain and Sprocket set metalmonkey SV Talk, Tuning & Tweaking 1 08-03-10 07:49 AM
