Old 05-03-13, 06:47 PM   #1
Dougs
Default Side panel infill
Looking for the wee triangle infill side panel for a pointy 10 plate left side(when sitting on the bike ).
Old 05-03-13, 09:07 PM   #2
phil24_7
Default Re: Side panel infill
If it helps, any from a K4 on will fit. The K3 is a different shape.
Regards
Old 05-03-13, 09:30 PM   #3
Dougs
Cheers Phil, just a wee project Im doing. I want to fit a waterproof cigarette socket into the panel so I can use this to plug in my heated vest. This would be the shortest route so no unsightly leads all over the place. so just looking for a spare panel to try my idea out.
Old 05-03-13, 11:19 PM   #4
phil24_7
You cuold mount one just behind that on the exposed part of the rear subframe. It's out of the way enough but still accessible and isn't very noticeable. This is where I have my autocom socket fitted. Alternatively, you could make up a bracket and fit it under the seat then you just need an extension lead to take it from your jacket to the socket. The bonus of this is that when your not using it, you wont see it.
curvy R/H underseat infill panel Wideboy Stuff Wanted 0 18-11-12 07:22 PM
Seat cowl Infill panel Elliott Stuff Wanted 0 19-11-11 10:00 AM
Sv650 k5 tank infill panel curlylee Stuff Wanted 0 09-11-11 07:31 PM
Mirror Infill Panel Screw toby_smith SV Talk, Tuning & Tweaking 1 09-07-10 08:13 PM
where can i get a infill panel for an 09 sport? nelly SV Talk, Tuning & Tweaking 6 28-06-09 01:26 PM
