Old 16-03-13, 07:13 PM   #1
muzikill
muzikill's Avatar
Default Sv650s K3 new chain & sprockets diy
thought i would do a thread to let others see you can do it yourself. I bought a kit from here...
http://www.wemoto.com/bikes/suzuki/s..._sprocket_kit/
And a chain tool
http://www.ebay.co.uk/itm/2008938508...84.m1439.l2649
So 1st of all today i stopped the back wheel from turning so i could loosen the front sprocket nut ready for replacement. Then i got about replacing the rear wheel sprocket, nuts were tight as fook. This gave me a chance to clean up all the areas surrounding the rear shock & the rear wheel itself along with greasing all the necessary parts to ready the bike for the season ahead.
Old sprocket vs new. I posted a picture of the old one the other day & a few replies said it was done but after 27k i don't think it looks bad tbh.
Here's how the rear looks, ready for the next stage of replacing the chain and the front sprocket.
Here's the tool i used & a link to you tube showing how to use it
http://www.youtube.com/watch?v=isWYsAnZ4jQ
tbc ..........
Old 16-03-13, 07:26 PM   #2
Runako
Default Re: Sv650s K3 new chain & sprockets diy
So where's the DIY?
Expected a vid, or write up. Maybe this is coming ...
Edit: Apologies.
Old 16-03-13, 07:43 PM   #3
muzikill
muzikill's Avatar
Originally Posted by Runako View Post
So where's the DIY?
Aye, you need to slow yer net life down a bit !
Old 17-03-13, 08:15 PM   #4
muzikill
muzikill's Avatar
Just noticed the OEM chain is a DID chain & still cant find the old link to pop out, is there one on the factory fitted chain?
Old 17-03-13, 08:32 PM   #5
Ratty
Ratty's Avatar
Just grind the head off any pin and push it out. Don't risk using the tool to split it. Easier to grind it.
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 17-03-13, 08:47 PM   #6
r0ddy
r0ddy's Avatar
If you've got the grinder out you may as well just cut straight through the chain
r0ddy is offline   Reply With Quote
Old 17-03-13, 10:01 PM   #7
muzikill
muzikill's Avatar
Ta, will continue on wednesday, i shouldnt have to adapt the length of the new chain to match the old?
Old 18-03-13, 08:39 AM   #8
markc123
If you bought the chain specifically for the Bike, then it should have been supplied with the correct number of links. It will the say number of links on the packaging, and then you can reference this with the manual.
Old 18-03-13, 03:19 PM   #9
absolutely nothing wrong with the old sprocket.
Old 18-03-13, 03:31 PM   #10
muzikill
muzikill's Avatar
Too late now mate, upon the advice of others i bought the whole thing. 27k of wear on that factory fitted rear sprocket, which in comparison looks like hardly any wear. I should commend myself on my chain cleaning/oiling expertise. I suppose it gives me a back up in case the new one goes to pot.
Chain and sprockets Endellion For Sale - SV's and SV related items 5 27-02-10 07:21 AM
chain and sprockets kurtis.randle SV Talk, Tuning & Tweaking 36 11-04-09 10:26 PM
Chain and sprockets Girth SV Talk, Tuning & Tweaking 22 14-11-08 01:16 AM
New Chain and sprockets? gavinsky23 SV Talk, Tuning & Tweaking 14 05-03-08 12:13 PM
Chain & Sprockets!!! Last Action Pimp SV Talk, Tuning & Tweaking 3 06-12-05 09:28 PM
