20-03-13, 02:52 PM | #1 |
Master cylinder banjo bolt thread size?
You probably wouldn't think a simple bolt could cause any problems, but after threading my master cylinder with one the other week, my replacement cylinder came today and thought I would screw in the brake lines prior to swapping the cylinders over. The bolt the new (used) M/C came with fitted fine but it's only for a single brake line (one hole) so went to put my dual line bolt in ,which is the same barring having holes for 2 lines, it screws in about half a turn and doesn't want to go any further. Needless to say I didn't try and force it for fear of threading another M/C.
It's weird as my bolt was in the old M/C so you would have thought it would have fit straight back in. The only difference apart from length, is that the bore of hole through the bolt is narrower on my old bolt then the new single hole bolt, could that be the reason? Anyway, I'll just have to order another bolt and try that, where's best to go to? The code on the single hole bolt is 7P, does anybody know the code of the dual line banjo bolt? |
20-03-13, 03:00 PM | #2 |
Re: Banjo Bolts
Compare the threads on the two bolts - they're probably a different pitch (i.e. one has bigger threads than the other). You need to make sure you get a new double bolt with the correct pitch thread.
20-03-13, 03:12 PM | #3 |
Re: Banjo Bolts
If you need any of those bolts back from when I bought your lines, let us know.
20-03-13, 03:13 PM | #4 | |
Re: Banjo Bolts
Just done a bit more digging. The lines that I removed were HEL braided lines and apparently they (HEL) are notorious for sending out the wrong pitch banjo bolts so god knows how it even got in there in the first place. Does M10 x 1.00 sound like the correct pitch to you? Also when I was digging I've come across these, worth the extra expense? http://www.svracingparts.com/product...roduct=1747418 |
20-03-13, 03:15 PM | #5 |
Re: Banjo Bolts
20-03-13, 03:22 PM | #6 |
Re: Banjo Bolts
20-03-13, 03:35 PM | #7 |
Re: Banjo Bolts
Think I'm best trying to find somewhere local that sells them, take the M/C with me and try them out. The smallest things are a right pain!!!
20-03-13, 04:19 PM | #8 | |
Re: Master cylinder banjo bolt thread size?
There is a difference between late 90's and current master cylinders! I've found this out at the cost of a M/C!
The later pointy M/C's are 1.25 pitch Stolen from Goodridge Quote:
RIP Reeder 20/07/1988 - 21/03/2012. Always missed squire!!! Every year we meet old friends, gain some new ones, lose old ones and you always remember them all. “Live as if you were to die tomorrow. Learn as if you were to live forever.” Mahatma Gandhi Last edited by andrewsmith; 20-03-13 at 04:20 PM. |
20-03-13, 04:26 PM | #9 |
Re: Banjo Bolts
20-03-13, 04:29 PM | #10 |
That's what I'll ask for then when I go the bike shop tomorrow and try them out. My current (now knackered) M/C is of a K4 and replacement of a K3 so will be the same.
Rear Banjo Bolt Size | Sideshow#36 | SV Talk, Tuning & Tweaking | 2 | 06-07-09 10:31 AM |
curvy master cylinder banjo bolt thread size? | stuballs | SV Talk, Tuning & Tweaking | 1 | 01-03-09 05:18 PM |
What pitch is the rear master cylinder banjo bolt? | northwind | SV Talk, Tuning & Tweaking | 7 | 27-04-07 04:54 PM |
Anyone know the '99 rear master cylinder brake thread size? | Ter | SV Talk, Tuning & Tweaking | 2 | 19-10-06 05:13 PM |
What size is the banjo for the rear master cylinder? | northwind | SV Talk, Tuning & Tweaking | 11 | 27-04-06 11:08 PM |
