Old 24-03-13, 09:23 PM   #1
Winder
Winder's Avatar
Default How to connect 12v accessory socket?
I have done a search on this and have found a few threads covering what set up is best. As my bike lives outside now i don't have the option of plugging in a battery charger and the sockets main use will be sat nav so i think having the socket live only when the bike is running is the best option for me.
Could some one please let me know what relay i will need and how i wire it to run from ignition?
I have a pointy so the lights always come on with the engine running. Is it as simple as running the live from the rear lights/headlight? Where in the circuit to i put the relay?
Old 24-03-13, 09:35 PM   #2
Tomor
Tomor's Avatar
Default Re: 12v accessory socket
Get one of bibs relay boxes? Simple to install and can plug in anything that you can stick a +ve and -ve bullet connector on. Highly recommended as I have on for my autocom on the v strom.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 24-03-13, 09:46 PM   #3
Winder
Winder's Avatar
so with this everything connected to it is only live when the bike is running? I'll search it mate, cheers
Old 24-03-13, 09:48 PM   #4
Tomor
Tomor's Avatar
Yep, connected so comes on with the tail light.
Old 24-03-13, 09:53 PM   #5
Winder
Winder's Avatar
Sweet.
Old 24-03-13, 09:55 PM   #6
Skybaba
Default 12v accessory socket
Yeah, Bibio's gizmo is highly recommended.
Here's how I fitted mine:
http://forums.sv650.org/showthread.php?t=188982
Old 24-03-13, 10:24 PM   #7
Hold on, no disrespect to bibs fuse thingy, but there is no need to fit one of those if you only need a 12v socket for a sat nav.
Get yourself a 12v automotive relay off amazon or eBay £4-5, some 6.4mm spade connectors and an inline fuse.
Put a 10amp fuse in it, live and neg feed to the relay, a switched supply for the trigger from the headlight or something.
Old 24-03-13, 10:31 PM   #8
Winder
Winder's Avatar
Thanks for that. I read through your own thread on this subject while these replies came in and thought that a second socket under the seat would be perfect for charging my phone/camera while touring and i also have heated grips wired straight to the battery at the minute. So my first post was true at the time of typing but is now a big fat lie! Went from 1x12v socket to 2x12v sockets and heated grips in minutes!
Old 24-03-13, 10:33 PM   #9
In that case, one of bibs fuse box thingys would be ideal
Old 24-03-13, 11:10 PM   #10
Dicky Ticker
12v sockets fitted, fused, direct to/from the battery allow you either take power from the battery without having the ignition on,or feed power to it as in charger[optimate]
Leaving the ignition on without the engine running is not good
I can leave my phone or satnav under the seat on charge without leaving my keys in the ignition
I don't like the idea of having wires running to pockets or tank bags while riding and having to leave my keys in the bike with the ignition on when I am stopped if I want to charge or use the power of the battery
Accessory socket problem - Curvy. Skybaba SV Talk, Tuning & Tweaking 12 30-01-13 11:24 AM
Windows XP sp3 - Wifi connection issue, showing networks in WZC but won't connect? Paul the 6th Idle Banter 23 02-05-12 08:07 PM
How to connect to a Ichat user from a PC Grant66 Idle Banter 8 23-02-10 08:51 PM
Connect 3d Radeon X1800XT 256MB for Sale (Graphics Card) SpankyHam Idle Banter 0 16-08-06 04:47 PM
accessory websites goldengraemes SV Talk, Tuning & Tweaking 4 24-04-05 06:27 PM
