Old 25-03-13, 10:37 AM   #1
daveyrach
Default Carb syncing fuel question.
So I am going to do the above this weekend, I have vacuum gauges and all that guff. There is one step I am a little unsure about according to the Haynes manual. It says to remove the fuel tap vacuum hose from the rear intake port (fine with that) and apply 1-2psi and clamp the pipe to keep the fuel valve open, does that mean suck or blow in the pipe, my brain tells me suck as the intake would do this when running would it not?
Is this job relatively straight forward, it seems to be and do I need to remove the tank or can I do it with it in situe?
Old 25-03-13, 10:45 AM   #2
Default Re: Carb Syncing
Suck
Old 25-03-13, 10:58 AM   #3
daveyrach
I have a brake bleeder like this, can I use this to apply the vacuum?
Old 25-03-13, 11:20 AM   #4
Wideboy
Evel Knievel
Wideboy's Avatar
I've always managed to do with with the fuel already in the carbs and lines before it conks out
05 DRZ400E
RIP hovis
Old 25-03-13, 11:20 AM   #5
Dipper
Dipper's Avatar
Default Carb Syncing
Or put a tee in the vacuum line to the tap, then you've got a permanent take off point for balancing.
Dipper is offline   Reply With Quote
Old 25-03-13, 11:26 AM   #6
daveyrach
True but it would need blanking off.
Old 25-03-13, 11:31 AM   #7
Dipper
Dipper's Avatar
Yep, it's worth fitting a permanent take of on the front as well if you've got a Curvy as its a nightmare to get to. I'm pretty sure Bibio sells kits for this.
Old 25-03-13, 11:47 AM   #8
daveyrach
Anyone know what size the vacuum hose is (I.e Internal and External Size) and how I add an extension to the front intake?
Old 25-03-13, 01:42 PM   #9
Serdna
I just added a bit of fuel line about 10 or 20cm long to the front vacum take off and blanked it off with a bolt. Works a treat. it pokes out by the radiator/coolant resevoir. I put bit of tube on the tank vacum and just give it a suck occasionally to fill the float bowls. You wont get fuel in your mouth because its just vacum working a diapragm. Obviously if you suck that pipe and get fuel in your mouth your diaphragm is faulty, but you would probably have running issues already if thats the case.
Any chance i could come around and use your guages sometime next month? Im only in oxford.
Old 25-03-13, 01:47 PM   #10
Serdna
On how to add it, you probably need to take the carbs off to get to it but you might be able to get to it with just the airbox off. If i remember correctly i think the radiator being in the way is the biggest difficulty. Either way once you've done it next time will be a 5min job adjesting the carbs.
Carb fuel leak. Scythe92 SV Talk, Tuning & Tweaking 15 17-05-18 05:56 PM
7.5k service carb syncing advice? charlie53 SV Talk, Tuning & Tweaking 10 23-03-11 05:25 PM
Carb vs Fuel injected florida650 SV Talk, Tuning & Tweaking 18 20-07-07 05:21 PM
Carb syncing at 4000RPM not Idle!?.. kciN SV Talk, Tuning & Tweaking 19 11-05-06 02:08 AM
Carb syncing svrash SV Talk, Tuning & Tweaking 2 13-02-06 09:01 PM
