Old 02-04-13, 08:57 PM   #1
sv650s king
Default Which chain and sprockets - SV650?
hi all
i got to change a my chain and sproket,
can anyone recomend and good ones to look at because
i need something which will last long time and take alot of stress because i do like to show off time to time thanks
Old 02-04-13, 09:01 PM   #2
muzikill
muzikill's Avatar
Default Re: need a new chain and sproket for mine sv650
wemoto
Old 04-04-13, 11:38 AM   #3
ChrisCurvyS
ChrisCurvyS's Avatar
Default Re: Which chain and sprockets - SV650?
Yup - lots of choice on one page with Wemoto. Got mine from there - can't remember exactly which ones I got but paid a bit more for branded steel chain and sprockets and they've lasted really well.
About 12k of hard riding and not a single chain adjustement yet! With a Scottoiler thought but still pretty good going.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 04-04-13, 11:43 AM   #4
Biker Biggles
Biker Biggles's Avatar
I wouldnt bother spending too much money if you are going to abuse it though.Even the best will fail if you dont look after it.
Can anyone help me fit chain and sprockets? sam anon Thames Valley 2 20-10-11 12:36 PM
New chain & sprockets - where from? Telford_Tim SV Talk, Tuning & Tweaking 1 13-05-11 06:54 AM
old chain new sprockets ? barwel1992 Bikes - Talk & Issues 14 28-07-10 02:21 PM
Chain and sprockets sunshine SV Talk, Tuning & Tweaking 6 01-03-10 10:38 PM
new chain and sprockets Warren Bikes - Talk & Issues 6 22-11-04 05:38 PM
