Old 07-04-13, 09:05 AM   #1
muzikill
muzikill's Avatar
Default Sv alarm connector.
Ive opened it up. Is it supposed to have a metal thingy bridging all the connectors together?
Old 07-04-13, 03:08 PM   #2
Default Re: Sv alarm connector.
What alarm connector?
Old 07-04-13, 03:20 PM   #3
muzikill
muzikill's Avatar
Exactly. According to the book of lies my sv should have a alarm connector. I've finally sussed out the circuit. If it did have one its gone during the alarm fitting!
Old 07-04-13, 05:58 PM   #4
OK, so we know it's not an alarm connector, so, I'm intrigued - what did you open?
Old 07-04-13, 06:11 PM   #5
muzikill
muzikill's Avatar
Default Re: Re: Sv alarm connector.
The joint block for all the rear light neutrals. Not clearly shown on any wiring diagrams tbh.
Plus i got caught out with this little loop.
http://www.svrider.com/forum/showthread.php?t=150676
I dont know how the fitter discovered that little shortcut to the front spark plug curcuit, unless its common on most bikes but it had me going round in circles looking for the missing link. It literally was.
Where to buy this connector? djotanov SV Talk, Tuning & Tweaking 6 22-11-11 09:02 PM
connector not connected mart SV Talk, Tuning & Tweaking 2 27-10-08 07:55 PM
Interesting discovery (alarm connector native to loom) Baph SV Talk, Tuning & Tweaking 10 24-08-08 04:07 AM
Indicator connector MiniMac Stuff Wanted 3 07-06-08 04:59 PM
Can anyone identify this connector? cb9002 SV Talk, Tuning & Tweaking 6 14-06-07 10:39 PM
