just broke one of the magnets inside the speedo drive , the bit with the wires going to it, and now its not working , can you replace the magnet or do I have to replace the whole thing ? its of a 1999 sv650s curvy , will any do or does it have to be of a 1999 sv curvy thanks
Ive got one that works if you get stuck, one of the 4 tangs is broken but its fine. PM me, it wont be expensive!
sure it still works ? as one of the metal bits think its the magnet inside mine broke and now its not working , just checking as need one , mot next month thanks ,
You need one off a curvy mate. The later ones are different and make the curvy speedo read twice as much.
that's sounds brill taylor , can tell every one iv had bike up to 200mph lol , thanks for your help
It worked when I took it off the bike, return it, if its no good. Leave it with you, maybe others can comment.
will see if another comes up over weekend if not will give you a shout thanks again
Haha yeah. Mines been right round the clock and back up to 0 again haha. Just did that to see if it would when it was in haha. Probably just short of 100 actual mph i guess
#9 |
If you've still got the lump that broke off, you could glue it back on with hot glue or araldite. Mine's got one of the tags hot glued on at the moment.
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan Now: Blue FZ6 Fazer |
#10 |
no I don't still have it , bit mad in garage chucked it lol never find it now , so just have to try and get a new one ,
Speedo drive rotor broken. | Elliott | SV Talk, Tuning & Tweaking | 12 | 26-06-12 11:21 AM |
SV650S-K3 Speedo failed (random numbers) - Rotor seems OK, speedo drive problem? | Tallguy | SV Talk, Tuning & Tweaking | 4 | 25-05-12 12:38 PM |
Broken external hard drive | FG1 | Idle Banter | 11 | 21-10-10 08:28 AM |
Broken speedo drive & regulator. | achapman01 | SV Talk, Tuning & Tweaking | 1 | 19-07-10 12:04 PM |
Speedo broken | Warthog | SV Talk, Tuning & Tweaking | 6 | 19-03-08 04:17 PM |
