Old 22-04-13, 09:48 AM   #1
granty92
Default speedo drive
so mine is completely not working now, read 0mph all the time and says im not doing any miles at all, need speedo drive for 2003 pointy anyone on here selling one?
Old 22-04-13, 11:46 AM   #2
saucysaunders
Default Re: speedo drive
I have the wheel spacer bit but not the rotor as this broke. Any good to you?
Old 22-04-13, 12:28 PM   #3
granty92
unfortunately not, my rotor is broke also so need the whole thing :/ cheers anyway
Old 22-04-13, 01:32 PM   #4
Nobbylad
Nobbylad's Avatar
Is this any use to you?
Old 22-04-13, 01:50 PM   #5
granty92
could be yes, could i just cut my one off and connect the wires with this one? how much do you want for it?
Old 22-04-13, 02:11 PM   #6
Nobbylad
Nobbylad's Avatar
Hmmm....I think the part numbers are different between K3 (34990-17G00) -K8 (34990-17G30).
I seem to recall there's a material difference, but I don't remember what it is.
Old 22-04-13, 02:16 PM   #7
granty92
so no way i could attach the wires?
Old 22-04-13, 02:56 PM   #8
Nobbylad
Nobbylad's Avatar
You'd be better taking yours apart to see why it's not working, checking the teeth are all present on the rotor etc and also checking the wiring/connection at the speedometer end itself (assuming you haven't already done this).
If the rotor is damaged, you could probably just replace it with this one, however you'd need to check it's compatible.
Old 22-04-13, 02:57 PM   #9
Nobbylad
Nobbylad's Avatar
http://forums.sv650.org/showthread.p...ghlight=speedo
Old 22-04-13, 02:57 PM   #10
granty92
i know the rotor has 1 peice snapped, when the bloke come and changed my tyre a couple of weeks ago he told me it had snapped,
SV650S-K3 Speedo failed (random numbers) - Rotor seems OK, speedo drive problem? Tallguy SV Talk, Tuning & Tweaking 4 25-05-12 12:38 PM
speedo drive ging6996 Stuff Wanted 0 28-04-09 05:05 PM
speedo drive Monkey_SDMF SV Talk, Tuning & Tweaking 19 18-11-08 03:19 PM
Speedo drive goody SV Talk, Tuning & Tweaking 0 13-08-07 07:30 PM
Speedo drive Normski Stuff Wanted 0 02-12-05 04:52 PM
