Old 27-04-13, 10:15 PM   #1
dylandun
Default electrics are dead
ok well tried to start my bike.. usuall clicking noice from the started when the battery is dead. charged it up turned it on started fine little bit hesitant though.
so i turned it back off and on and then it tried to start normally then all the electrics died
i checked the fuses and they are fine well the 2 main ones that is...
anyone else had this problem what was it?
Old 27-04-13, 10:38 PM   #2
dylandun
Default Re: electrics are dead
took it all apart checked all the connections and put it back togethr because they looked fine.. and then it started? what could it have been ? any ideas
Old 27-04-13, 11:02 PM   #3
Fallout
Fallout's Avatar
Sounds like either a loose connection, corrosion on terminal or moisture. Is it kept outside?
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 28-04-13, 06:07 AM   #4
dylandun
Yeah I think it may be moisture a few of the connections looked as thou they were getting moist
Yeah it's outside covered
Old 28-04-13, 02:21 PM   #5
warrenhewitt10
Could this be another green plug issue.
Old 28-04-13, 03:30 PM   #6
dylandun
Green plug ?
Old 29-04-13, 11:19 AM   #7
Shawthing
Shawthing's Avatar
Ignition switch connector to the loom:
If it gets water in it, then connectors can corrode, become resistive and intermittent ,dumping power (heat) until failing open circuit.
Lift the tank, take top off airbox, loosen the two clamps holding bottom of airbox to the throttle bodies, lift and push bottom of airbox back and you should be able to get to the green connector. Open and inspect.
SK9 Sport Black Delkevic can.
Old 03-05-13, 09:16 AM   #8
dylandun
i checked no corrosion on any of the electrics :/
electrics completely dead on 99 sv 650 goyboy SV Talk, Tuning & Tweaking 3 12-04-12 06:03 PM
Dead bike :( Electrics sprocket SV Talk, Tuning & Tweaking 3 03-03-12 02:09 PM
electrics dead - what to do? weazelz SV Talk, Tuning & Tweaking 6 18-02-07 03:08 AM
Electrics dead, Except alarm..... which works. HELP! superking SV Talk, Tuning & Tweaking 10 08-12-06 08:06 PM
Big problem with electrics, bike is dead ayfy SV Talk, Tuning & Tweaking 4 11-12-05 11:03 PM
