Old 07-05-13, 03:13 PM   #1
Steve_God
Default GSXR Front End Swap - Raised Clip-Ons without changing cables?
OMO,
Has anyone who's done a front end swap, also used raised clip-ons?
If so, can you say if you had to use longer cables than standard?
I ask because the GSXR forks are shorter than those of the SV, so I was wondering if others had been able to use the small amount of slack in the cables to fit raised clip-ons using original cables?
Old 07-05-13, 03:30 PM   #2
Default Re: GSXR Front End Swap - Raised Clip-Ons without changing cables?
Yes, I've done it on a curvy.
Is possible to get away with it, but cables are very tight at the extreme end of the steering lock.
Choke cable did require replacing with a longer one, but not an issue on a Pointy.
Clutch cable wasn't a problem, I re-routed that, but this didn't work with the throttle cables
Clip ons for gsxr front end mod widget Stuff Wanted 2 14-10-10 07:38 PM
GSXR front end - Ducati clip ons? maviczap SV Talk, Tuning & Tweaking 17 14-06-10 09:03 PM
WTB: raised clip-ons for curvy mnrsmith Stuff Wanted 0 30-03-09 08:35 PM
TL 1000s clip ons (gsxr front end swap) ianofbhills For Sale - SV's and SV related items 0 11-12-06 11:04 PM
