Old 11-05-13, 07:15 PM   #1
SV Shaun
Default Which exhaust can, where to cut? Curvy.
Hi guys
So the BMF is coming up next weekend and im heading up there to buy a new exhaust. Unsure on the brand atm. Anyway, I was looking over the whole exhaust system today, and im abit confused. To me it seems like I couldnt just buy an end can and be done with it... I need to buy the can with that large exhahst link pipe. Cant explain it.
Basically how would i swap my 2000 s exhaust (standard) for a new can. Is it a simple swap or any cutting involved??
The link pipe isnt a simple pipe, it goes into the back of the engine. Im at a total loss???
Old 11-05-13, 07:25 PM   #2
aesmith
Default Re: aftermarket exhaust swap?
What bike? If it's an SV650 then you need to cut the original.
Old 11-05-13, 07:39 PM   #3
SV Shaun
Yeah i ride a 2000 sv650s. Everything is standard and i want to change just the end can. Give it some style and some sound
Where would i need to cut it?
Old 11-05-13, 08:00 PM   #4
You need to cut the pipe, and then reconnect it with the link pipe supplied with the end can, if it needs one.
The link pipe is sometimes needed to get the correct angle for the new exhaust hanger, or if the end can has a different diameter connecting pipe
Old 11-05-13, 08:01 PM   #5
You'll cut the OEM exhaust somewhere between the pillion footrest and the riders footrest usually
Old 11-05-13, 08:11 PM   #6
SV Shaun
Okay i think ill need to get some tools in hahs.
Can you recommend any exhausts that are not to expensive to buy new, and are nit ti loud?
The link pipes that come with the end cans, do they slip straight on or are some a different size?
Old 11-05-13, 08:18 PM   #7
otaylor38
I think its usually 50mm further back than the weld you can see before the end can.
This may vary depending on brand, mines a beowulf if that helps
Old 11-05-13, 08:27 PM   #8
same size to fit the cut exhaust and then connect to the can. usually 52mm if I remember correctly.
Fuel cans are well made and quiet. I've got one
They were giving the Org discount on cans
Also you could give them a call to see if they have any seconds, with slight manufacturing faults
but beowolf also make nice cans
Old 11-05-13, 09:56 PM   #9
SV Shaun
A Fuel can was a good contender, i have to admit. Its either do this at a small cost, or go all out and buy a full system
Old 11-05-13, 10:25 PM   #10
otaylor38
I guess youll just have to ask yourself if the cost of a full system is worth the money for the amount of gain you get. I decided on a slip on as its only for road use for abit of a tastier sound haha.
Anyone know how big the performance benefits are for a full system? M4 etc?
Curvy Exhaust... Jammy Guildford Massive 0 24-07-12 12:30 PM
Curvy Exhaust TheOnlyNemesis Stuff Wanted 1 25-04-12 07:04 PM
Curvy Exhaust Paris2 Stuff Wanted 2 11-02-12 08:45 PM
Curvy exhaust fit K8? savoury SV Talk, Tuning & Tweaking 1 10-09-08 11:58 AM
Curvy exhaust anyone ?? Soprano69 Stuff Wanted 7 31-10-07 09:25 PM
