Old 16-05-13, 01:26 PM   #1
sicknote
Default SV650 curvy usd GSXR front end kit complete
Complete GSXR / USD front end kit to fit SV650S mk 1 99-02
*GSXR 750 USD LH & RH forks
*GSXR 750 upper and lower triple clamps
*GSXR750 left and right handlebars
*sv650 headstock bearing conversion kit
*Hayabusa front wheel & discs with a very good Michelin pilot sport tyre.
* fitted rare earth magnets, and the required speedo sensor
*TL1000S front fender and an extender.
Good points : all the parts you need to swap out your entire sv650 front end, you will just need a pair of brake calipers
The Top yoke has been drilled to accept bar clamp risers ( easily hidden with top yoke cover )
I found the bike rode better with gsxr clip on bars ( included )
Bad points: The RH fork leg casting is cracked at one of the clamp bolts
grazed on the top adjuster and also is weeping fork oil from the seal.
I bought another RH GSXR fork leg ( bent stantion ) see pics, intending to swap the clamp and adjuster when I changed the fork seal, but never got around to doing the job , but its not hard on these forks it all undoes from the bottom. this spare RH fork is included so you can swap the parts out when you replace the fork seals and fill with fresh oil ready to fit to your SV.
The TLS fender has some damage to mount points but still sturdy.
£450 or best offer. collection only , berkshire
pics in my album http://forums.sv650.org/album.php?albumid=970
Old 16-05-13, 02:21 PM   #2
dirtyred619
Default Re: SV650 curvy usd GSXR front end kit complete
Won't be needing this myself but I'd imagine they'll be plenty of interest in this!
Old 16-05-13, 04:05 PM   #3
littleoldman2
littleoldman2's Avatar
Details on required brake calipers ?.
Old 16-05-13, 05:38 PM   #4
sicknote
as for calipers, i ran six pot tokicos in this setup.
I have them up on Ebay at the moment
If i was doing it again i would probably go for four pots as easier to keep in shape in english climate and four pots seem to work fine on something this light.
One thing i noticed swapping out SV650 bottom yoke, stock item weighs an absolute ton compared to alloy gsxr750 item so a fair weight saving to be had by doing the swap.
gsxr USD front really makes a big difference to the ride of the sv much more stable , especially when matched with a decent rear shock
Gsxr front end complete widget For Sale - SV's and SV related items 6 20-05-12 08:29 PM
GSXR 750 front end complete for SV £850 payner123 For Sale - SV's and SV related items 19 04-07-11 05:31 PM
wanted: GSXR complete front end for k4 sv kaimera TOTALSV Ireland 4 05-06-11 08:11 PM
GSXR 1100 L front end (almost) complete Owenski For Sale - Other Bikes and General biking items 0 15-10-10 10:05 PM
GSXR Complete front end s7uyj SV Talk, Tuning & Tweaking 8 30-09-09 05:55 PM
