Old 24-05-13, 09:50 PM   #1
stranger12
Default SV650 oil level?
hi guys,
today i had a little heart attack as when switching the bike on , the oil light came on and stayed . i then put the bike on stand and watched through the glass and the level was below low or L . i could not see it at all.
i then switched it on and the light went off, it would have surly stayed on if low on oil , wouldn't it ?
anyways i then asked my partner to come and check it while i centre the bike(standing on it).
it was then showing as full.
i guess based on that my oil is ok and the light came on because maybe my bike was parked for 3-4 days on its side
is that happening to you guys as well( light comming on when on stand ) ?
do you check the level by asking someone else to stand on it and you check it or just use rear stand ?
Old 24-05-13, 10:21 PM   #2
Pete7
Pete7's Avatar
Default Re: sv650 oil gauge
Nope, normally do some sort of scary balancing act with me holding the bars with one hand whilst bending down to see the level. It will end in tears one day.
Pete
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 25-05-13, 06:50 AM   #3
jambo
jambo's Avatar
The oil light its a pressure switch trigger, not a volume sensor, that it's, that when the engine is not running, the oil pump is not running, there is no pressure, so the light's on. Perfectly normal, however, I suspect you just noticed it today. As long as the level is ok when the bike is vertical, and the oil light goes out when the engine starts you're cool
Jambo
Sent from my thingie
Old 25-05-13, 08:09 AM   #4
Jambo
This
It should stay on for a second from the engine catching and revving up, it comes on (along with the low fuel light and neutral) when the ignition comes on, majority of bikes operate with the same circuitry.
The only time it should be on is when there is a problem down there, if you want to check it quickly get a brick under the sidestand and act as a balance while checking
Old 25-05-13, 08:46 AM   #5
TheRuffellator
Jambo
What he said ^
Old 26-05-13, 09:04 AM   #6
stranger12
Default Re: SV650 oil level?
thanks very much .mine aslways it is on as soon as the ignition is on ( not bike) regrdless of bike position but goes off as soon as it is switched on, i guess it is normal based on the posts in here
the only time that it is going to be problem is if the light is on past when engine is on ? would it stay on if low pressure of low oil while on ?
Old 26-05-13, 09:08 AM   #7
Serdna
It would stay on if you have low pressure. But when it comes on the oil level is past critical and its already too late probably. On my old engine the oil went way below the L on the sight glass and the light never came on. The engine only lasted a year after that episode.
SV650 Race Exhaust System or High Level Can JonnyAnnett Stuff Wanted 0 14-06-11 04:36 PM
99 sv650 yellow, lowers, hi level remus, KnN + more £1000!! libo9889 For Sale - SV's and SV related items 3 03-05-10 01:30 PM
hi-level carbon can for sv650 k5 H_0_L_A Stuff Wanted 1 13-02-09 12:15 AM
SV650 Curvy, Scorpion st/st can + High level pipe gc350 For Sale - SV's and SV related items 2 07-04-07 10:21 PM
2004 SV650 S Black twin hi-level exhaust, fairings & mor Guy H For Sale - SV's and SV related items 0 01-11-06 03:04 PM
