Old 25-05-13, 10:04 PM   #1
chris87
Default SV1000 bodywork clips - where from?
hi people,appologies in advance for no photos just now.
however i have had my sv1000 for a month now and unfortionately i have had a complete ( ASS )of a previouse owner as the work he done on the rear end is just a complete mess, hear is whats happened....i noticed my no.plate sat squint so i had a look and sorted it out however the brackets on the tail tidy looked like a home made job and very poorly done which led to a plate being lost so i remade a unit to hold the plate in place however it wasnt 100% i thought it would hold for a month or two but 2nd ride it was gone and had damaged my pyramid mudgaurd,so i decided to inspect the whole rear end of my bike O.M.F.G,. Basically the guy before hacked chunks of plastics out to fit in a upper gaurd inn i think its advertised on ( m and p ).com 80.00gbp. on even closer inspection he has hacked up the rear battery tray plastics to try install the no.plate light in withblack weather sealent lol and is a complete mess the indicators arnt salvageable either also the rear fairing on the bike is missing its original plastic holder tacks and the guy used black plastic bolts to secure it on.SO TO RECTIFY THIS.........i have researched these items and am just checking for any compatabillity problems people the mandp race upper gaurd plasticPowerbronze
Std Tailskirt Uses OE Light
544437
Be the first to review
s ,the battery tray and also (evo tech performance tail tidy),could some one point me in the right direction for the original rear fairing plastic bolt clip things thanks ps i will eventually get pics for you guys as im also curious about some wireing on the bike which i suspect as being hacked up,todays job on bike was wash and polish and respray radiator gaurd was rusty now primed sprayed (ford panther black and laqured) oo i know i go on but could you recomend any led rear indicators 10-30 quid
cheers
Old 25-05-13, 10:45 PM   #2
Default Re: SV1000 bodywork clips - where from?
Suzuki dealers sell Suzuki parts.
Old 25-05-13, 10:52 PM   #3
Ignore sid
Are these the things you mean? http://www.ebay.co.uk/itm/10x-6mm-Pl...item5af04cb473
Old 25-05-13, 11:46 PM   #4
chris87
yes chuffed as hell thanks lol i just hope this git hasent drilled the holes bigger to fit in the bolts he put in they are like that black plastic nut n bolts you get for no.plates :/ thanks again sweet ride in your profile pic btw
Old 25-05-13, 11:50 PM   #5
Thanks. If he has drilled them, you can get bigger versions of those clips. Have a search on ebay
Old 25-05-13, 11:51 PM   #6
chris87
yup they the ones from the rear fairing from scotland aberdeen
Old 25-05-13, 11:58 PM   #7
chris87
i just dont know what this guy was thinking he literally has butchered the bike, after i have sorted out this ill be giving the bike a service prob yoshi rs3 cans or maybe beowolf not sure yet.i must have crap luck as not that long ago i got a tack inmy tyre all fixed now though just gutted as cant ride it without a plate,also kinda scared to look how he has fitted the vacume scotoiler need to remove the tank for a better look,can i ask in your pic your sv has gold forks much interested is one
Old 26-05-13, 12:03 AM   #8
chris87
one last question about those clips when they are installed to get them out do you just push the centre of them in as i managed one and it was a beatch to work with lol
Old 26-05-13, 12:07 AM   #9
Lifting the tank is easy. Just remove the black diamonds under the seat, then the seat, then the two bolts at the front of the tank and it hinges up.
I've got gsxr600 forks on mine
Old 26-05-13, 12:10 AM   #10
Yep, push the middle with a screwdriver or something, then pull at the outside bit with your nails. It's easier if you can get your hand in to behind the clip and push it out from there. To put it back in, just pull the middle bit out so it is sticking out, insert the outer bit in the hole and push the middle bit back in.
Bodywork push clips suitable for Pointy? musne SV Talk, Tuning & Tweaking 8 01-02-12 06:35 PM
SV650 & SV1000 Bodywork Swopping? McFly SV Talk, Tuning & Tweaking 4 25-05-11 07:43 PM
Plastic clips on bodywork - where from? jonny.boyd SV Talk, Tuning & Tweaking 20 13-06-10 07:33 PM
SV650/SV1000 dream machine painted bodywork for sale squiglyzigly For Sale - SV's and SV related items 0 21-09-06 03:35 PM
Jubilee Clips curium SV Talk, Tuning & Tweaking 1 11-03-05 09:18 AM
