Old 27-05-13, 01:49 PM   #1
baldricc
Default pointy bits for sale
Sk6 rear subframe £25 (now sold). Top fairing £50 right hand front lower £40(just found small crack in front edge) in yhj.(Napolion blue) Also dash clock suround £10 Small side panels (pair grey under seat bits) £15. Good pair handle bars £20 Front and rear seats £25 for both. if interested in any of bits pm me open to offers. plus p&p any reasonable offers considered as i have had to put price.
Last edited by baldricc; 05-06-13 at 07:37 PM. Reason: found another item.had to add prices
Old 28-05-13, 02:28 PM   #2
muzikill
muzikill's Avatar
Default Re: pointy bits for sale
dibs on hugger, price?
Old 28-05-13, 02:38 PM   #3
The Guru
Needs prices as per forum rules.
Old 28-05-13, 05:33 PM   #4
Kenzie
Kenzie's Avatar
Do you have the toolkit cover off the undertray?
Old 28-05-13, 05:36 PM   #5
baldricc
Will check in the garage and get back to you
Old 29-05-13, 10:50 AM   #6
MrMessy
Do you have a rear wheel with disc?
MrMessy is offline   Reply With Quote
Old 29-05-13, 10:57 AM   #7
baldricc
Sorry just bits listed
Old 29-05-13, 01:13 PM   #8
scottp_15
If they are clip-ons that will fit a k7 I just need the left hand clip on if that would be possible?
Old 29-05-13, 07:24 PM   #9
punkyp
dash clock surround, that the glass/plastic part?
Old 29-05-13, 07:28 PM   #10
baldricc
Abs Plastic inner fairing what surrounds the clock unit
Pointy Bits for sale boredus For Sale - SV's and SV related items 9 07-10-11 06:02 AM
Pointy Bits For Sale Sideshow#36 For Sale - SV's and SV related items 20 19-01-09 10:51 AM
Pointy bits for sale cyphertheory For Sale - SV's and SV related items 27 09-06-08 09:48 PM
K4 Pointy Bits for sale Sideshow#36 For Sale - SV's and SV related items 27 04-09-07 06:46 PM
Pointy bits for sale andyaikido For Sale - SV's and SV related items 23 27-08-07 10:32 AM
