Old 30-05-13, 07:02 PM   #1
RavenWire
Default Change end can without cutting?
Just wondering, is there and end can that doesn't require any pipe cutting? Was looking at one of the Delkevic (mainly because they're really well priced) ones but it doesn't say whether you need to. If you can recommend a can while you're at it would be greatly appreciated
Old 30-05-13, 07:07 PM   #2
Tomor
Tomor's Avatar
Default Re: End Can Question
Unless you get a full system, you will always have to cut the stock can off as it is one piece.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 30-05-13, 10:37 PM   #3
SV Shaun
You have to cut regardless for an end can. Dont get a full system as you dont get much from it. Value, sound, power. Ive got a beowulf and sounds lovely. Had to cut mine but wasnt a prob for me
Old 31-05-13, 06:30 AM   #4
MarkB852
I'd have to disagree with that. A full system is much prettier.
Ready cut stock exhausts are often available on e-bay if that helps...
Old 31-05-13, 07:02 AM   #5
cheesypeeps
I just fitted a new scorpion exhaust to mine. My mate seemed to have no problem with cutting the pipe, but that's easy for me to say... I was just handing them the tools!
Old 31-05-13, 08:18 AM   #6
Yes, my full system looks really nice and my stock system is in the garage uncut ready for if I ever sold the SV.
You can't get away from cutting the stock system as the end can & pipe are welded together..
3 options.
1. buy a full system, expensive, but will look nice
2. Buy a 2nd hand stock system and cut that, saving your standard system. The pipes are stainless steel and will polish up nicely
With these options you have to remove the front header pipe where you run the risk of snapping the exhaust studs, unless you are very careful.
Option 3
Cut standard system
Fork spring change - change oil? GIZZY66 SV Talk, Tuning & Tweaking 14 05-02-12 04:59 PM
Cutting out Fraser24 SV Talk, Tuning & Tweaking 4 29-08-11 06:04 PM
Cutting Out FlyinCustard SV Talk, Tuning & Tweaking 44 09-05-09 03:16 PM
cutting out 01 sv650s SV Talk, Tuning & Tweaking 2 04-11-06 11:13 PM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
