Old 06-06-13, 11:44 AM   #1
cornishsv
Default Hi Flo or K&N oil filter?
Looking at get an oil and filter kit of fleabay and was wondering people's opinions on to go for the hiflow or k&n filter
Old 06-06-13, 11:47 AM   #2
daveyrach
Default Re: oil filter
Hi-Flo will do the job fine, Had K&N's before just a bit dearer does the same job though.
Old 06-06-13, 11:57 AM   #3
Pricey12
A lot of people like the K&N oil filter as it has a nut on the end to take it on and off, so is a bit easier.
Old 06-06-13, 03:09 PM   #4
stuR
Default Re: Hi Flo or K&N oil filter?
ive always had the hi flos as they are a bit cheaper n seem gd to me
Old 06-06-13, 03:10 PM   #5
warrenhewitt10
Ive had a number of Hi-Flo filters, never had any issues!
Old 06-06-13, 03:21 PM   #6
Hiflo are fine, if you get K+N don't overtighten.
Old 06-06-13, 07:00 PM   #7
Fordward
I always get K&N purely because my filter is a bitch to get a filter wrench round and the nut on the end is a god send come removal time.
Sent from my GT-I9300 using Tapatalk 2
Old 06-06-13, 08:16 PM   #8
Gimerk
I've used K&N before, preferred it due to the nut. Performance was like ... an oil filter!
Old 07-06-13, 01:25 PM   #9
Jason H
Jason H's Avatar
Removal is simple
You will need the following:
  • Old or cheap screwdriver
  • A hammer
How to:
  1. Hold screwdriver with the pointy end onto side of oil filter
  2. Apply hammer to top of screwdriver handle
  3. Use handle of screwdriver as lever to unscrew filter
  4. Job is Jobbed. Sit back and open a beer. (fitting a new filter is always advised at this stage also. Do not use screwdriver method to fit...)
Naked K5 - Now Red with sexy stripes!!
Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock
Jason H is offline   Reply With Quote
Old 07-06-13, 01:39 PM   #10
daveyrach
^^This
Air Filter & Oil Filter from TL1000R fit SV650? AkiraSV SV Talk, Tuning & Tweaking 3 04-08-11 05:19 PM
Spark Plugs, oil filter, Air Filter....Curvy 21QUEST For Sale - SV's and SV related items 2 14-01-10 10:04 PM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
OIL FILTER johndo SV Talk, Tuning & Tweaking 14 26-03-06 03:10 AM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
