Old 16-06-13, 02:35 PM   #1
Kathij
Default Non starter - electrical.
Hi,
I am having some serious problems with this SV650. Its basically been rebuilt and everything seems to work, then stop, then work then stop.
After diagnosing a fault with the Starter Relay after having no power anywhere on the bike we managed to get the dash to light up, and bypassing the power take off in the Starter Relay (fuse was loose and we were getting intermittent dash lights when wiggling it) it fired up and ran.
Since then i replaced the Starter Relay and now i am getting dash lights but no starter. First of all it was starting and running like a dream, but now it just spins the starter and getting nowt! Have checked the fuel system is all connected and am still getting dash lights.
Clutch inhibitor has been bypassed and have tried removing the clutch diode and bridging that as well, but for now we are getting nowt!
I have a basic electrical knowledge and a circuit tester, but am struggling with the diagnosis now!
Any help greatly appreciated
Dan (Kath's friend!)
Old 16-06-13, 03:57 PM   #2
Default Re: Electrical Faults.
Clarify: Only the starter spins or it spins the motor as it should?
And which model do you have?
Old 16-06-13, 04:28 PM   #3
Kathij
Default Re: Non starter - electrical.
Thanks for your swift reply, it was a loose connection.... All now working as it should, now for the brakes...
Cheers again, Kath.
Starter Relay, Starter Relay connector, Rear cush drive rubbers. yorkie_chris Stuff Wanted 4 08-07-11 09:32 PM
Electrical problem, nothing happens when I press the starter sprocket SV Talk, Tuning & Tweaking 2 08-05-10 06:22 PM
Electrical Issues - Starter Relay Problem? cornflakes Bikes - Talk & Issues 7 11-02-10 11:49 AM
Non starter. AndyBrad SV Talk, Tuning & Tweaking 61 26-05-09 07:50 PM
Non-starter for ten... Bluewolf SV Talk, Tuning & Tweaking 6 23-08-07 09:21 AM
