Old 19-06-13, 11:48 AM   #1
granty92
Default Clean rusty bottom yoke?
i have rust on my bike on the bottom yolk/yoke, it only looks like surface rust but still looks yuk, how can i get rid of it? just scrub away or any particular stuff?
Old 19-06-13, 03:55 PM   #2
dirtyred619
Default Re: Clean rusty bottom yoke?
Autosol probably will do the trick.
Old 19-06-13, 04:40 PM   #3
Matt-EUC
Autosol is good. Works for small scratches too, just be careful not to use too much.
Old 19-06-13, 06:20 PM   #4
Wideboy
Evel Knievel
Wideboy's Avatar
isn't the standard bottom yoke powdercoated on pointy's?
05 DRZ400E
RIP hovis
Old 19-06-13, 09:52 PM   #5
muzikill
muzikill's Avatar
Paint over it with hammerite silver. I got the aerosol spray and sprayed it onto a bit of card and used a brush from there. The silver is a almost perfect match
Old 20-06-13, 09:53 AM   #6
Pricey12
Think I may try this as my bottom yoke is starting to look a bit scabby.
Do I need top and bottom yoke? Gremlin SV Talk, Tuning & Tweaking 2 12-09-11 02:00 PM
Bottom Yoke Olly Stuff Wanted 2 01-07-07 06:41 PM
Rusty Yoke DarrenSV650S SV Talk, Tuning & Tweaking 5 25-02-07 11:02 PM
Chain Rusty After Lay-Up: How to Clean? Liam SV Talk, Tuning & Tweaking 8 01-04-05 01:49 PM
rusty bottom yolk. help. Dirty Baz SV Talk, Tuning & Tweaking 7 12-01-05 08:17 PM
