Old 19-06-13, 02:04 PM   #1
Lume
Default So went for a ride earlier...
So as the title says i thought i would go for a bimble, so set off and got about 5 miles and thought the bike was a bit "Whishy Washy", The bike felt loose at the back is the best description. So I thought "low tire pressure that's what that is!".
So i pulled over and checked the rear wheel, I could almost touch the rim if i pushed reasonably hard. So i thought "Crap, Best get home quick." so after a tricky ride home to get 40p and a rather scary trip to tesco for the Air Machine.
Turned out i had 6 PSI in the rear tire :S
But its fine now i have 32 PSI...
Note to self: check tires more often!
Old 19-06-13, 02:16 PM   #2
Default Re: So went for a ride earlier...
it's 36psi rear and 33psi front for the SV.
Old 19-06-13, 02:28 PM   #3
Pricey12
Are you sure you don't have a slow puncture / dodgy valve?
Don't rely on the machines at garages for an accurate reading as your tyres will be warm. Best to check pressures when cold.
Old 19-06-13, 02:38 PM   #4
Winder
Winder's Avatar
Must be something wrong there mate, you could leave a bike standing for years and it wouldn't lose that much pressure.
As above, check the tyre and valve over thoroughly for any leaks/foreign objects. And yes it's 33f 36r
Old 19-06-13, 03:55 PM   #5
Lume
I have a compressor at home so i can do tires at home it was just because i was out and about i needed it now, plus it was all locked up, I will be checking the tire later when im not busy.
Old 19-06-13, 04:37 PM   #6
PyroUK
PyroUK's Avatar
Argh! Karp!
Hope it isn't a big problem mate! Also still good for sat morning heading up to AR?
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 19-06-13, 05:06 PM   #7
Messie
The Teacer
Messie's Avatar
Moved to Bike Talk
had a bit of a moment earlier..... tom-k6 The Madlanders 2 18-09-10 08:59 AM
And here's one I washed earlier charlie13 Photos 12 23-04-09 07:13 AM
Does k5 fan switch fit in earlier rad tonny006 SV Talk, Tuning & Tweaking 1 10-08-08 02:07 PM
Should've done it earlier! ukhammy SV Talk, Tuning & Tweaking 7 22-07-08 10:54 PM
Why didn't I buy one earlier..... Tigerrrr....... Bikes - Talk & Issues 7 18-01-06 04:09 PM
