Old 22-06-13, 08:21 AM   #1
disco2
Default R&G frame sliders help please.
Hi all,
I have a set of frame sliders from r&g for my 04 sv650 naked.
These are a ebay win so I have the complete kit but no instructions
They are the ones with the bolt that goes right threw the frame,i have looked at the instructions on r&g,s website but they make no sense to me at all.
Can anyone give me some hints on fitting them PLEASE??????
Many thanks...
Old 22-06-13, 08:39 AM   #2
Dabteacake
Default Re: R&G frame sliders help please..
Pretty sure the long bolt goes through the frame and engine! The engine would need supporting from underneath so you can remove bolt and then add the bungs
Don't know anymore Han that though
Might need the bike to be upright so if you don't have a paddock stand maybe use ratchet strap from the bars to the roof to take the weight
Old 22-06-13, 09:28 AM   #3
You won't need to support the weight of the engine, as the other engine mounts will take the weight.
Old 22-06-13, 09:32 AM   #4
If you have the same ones as in this pic, looks like you need to remove the long engine mounting bolt in the centre of the engine and replace it with the RG one?
Then the sliders attach some how to the other bits in your kit?
http://www.bikehps.com/acatalog/Suzu...rotectors.html
Old 22-06-13, 09:44 AM   #5
muzikill
muzikill's Avatar
Default Re: Re: R&G frame sliders help please..
Unless the engine was mounted slightly off kilter. A trolley jack can be used to lift the engine if you have problems removing any bolts.
Different fitting of r&g sliders than the k3s btw.
Old 22-06-13, 12:11 PM   #6
dkid
Default R&G frame sliders help please..
+1
Old 22-06-13, 04:02 PM   #7
disco2
Many thanks guys all fitted quite an easy job all in all.
Old 22-06-13, 05:19 PM   #8
muzikill
muzikill's Avatar
How foosty did the bolt look? Lol
Old 22-06-13, 08:44 PM   #9
disco2
Lost me there buddy
Old 23-06-13, 07:17 AM   #10
muzikill
muzikill's Avatar
Middle bolt look rough when you took it out?
Which frame sliders? liam111 Bikes - Talk & Issues 3 28-01-13 12:37 PM
LSL Frame sliders? Dabteacake SV Talk, Tuning & Tweaking 5 27-09-12 07:04 PM
SV650S Frame Sliders sv650sfan Bodywork 3 26-06-07 08:08 AM
Suzuki frame sliders Jimmie SV Talk, Tuning & Tweaking 13 31-01-06 09:45 AM
