Old 23-06-13, 11:38 AM   #1
Knobby
Default Preload adjustments? Curvy.
Anybody got a later curvy that's got the adjusters at the top of the forks?
I now have a pair of these later curvy forks fitted to my SY model.
What way do I turn to stiffen the forks?
Old 23-06-13, 11:48 AM   #2
BBadger
Default Re: Fork Adjustments
clockwise. as to tighten, pushes the spacer down and thus more compression on the spring giving a stiffer feeling.
New fork oil also makes it heaps better.
Old 23-06-13, 12:58 PM   #3
timwilky
timwilky's Avatar
Nobody loves a pedant so here I shoot myself in the foot.
what do you mean by "stiffen the forks"?
Stiffness of a spring as I remember from mechanical engineering lectures 35+ years ago. (**** doesn't time fly!) is a constant. where K=F/x. F being the applied force and x the resulting displacement. So in short it is impossible to stiffen the spring assuming they are linear.
Applying preload simply increases the amount of initial force that is required to start to compress the forks. Changing the oil or on better forks adjusting the damping, changes the rate at which the compression/rebound takes place. It does not make them any "stiffer"
So if you wish to make the forks stiffer, change the spring.
Not Grumpy, opinionated.
Old 23-06-13, 08:21 PM   #4
Knobby
Cheers badge.
Old 24-06-13, 07:47 AM   #5
ees right yew know
Old 24-06-13, 08:17 AM   #6
timwilky
timwilky's Avatar
In what respect am I right!
Nobody loves a pedant?
here I shoot myself in the foot?
Time flys and it is a long time since I had Idris Yeo in ONC mech eng scream give me monkeys? (He had a 98% pass rate so his monkeys obviously stop thinking for themselves and did as told)
or the facts about a spring?
Old 24-06-13, 08:20 AM   #7
Well both really.
There is pedantry and what is true. What is also true is the stock springs are useless and the preload adjusters do 3/5ths of f*ck all to patch over the problem
Old 24-06-13, 03:44 PM   #8
Knobby
Default Re: Preload adjustments? Curvy.
Thanks for the replies but the first reply did the trick.
Old 24-06-13, 08:26 PM   #9
Really? Badger's right in that turning clockwise increases the preload, but not that it gives a 'stiffer feeling'.
It's the same spring under the same load - it's not stiffer.
Old 25-06-13, 11:43 AM   #10
BBadger
i understand and can explain it properly....but for the sake of this thread i wasnt using stiffer in its litteral sense.
The rate of the spring isn't changed therefore no effect on stiffness but if you had to quickly explain it those are the words i would use.
new springs and oil is the only way to sort the front end effectively at the end of the day.
and squid you should know im more of an ideal gas flow, head pressures and flow dynamics kinda guy.
preload for 2000 curvy Steve Stuff Wanted 2 02-03-12 12:48 PM
Curvy preload adjusters martin15s Stuff Wanted 0 13-06-11 04:25 PM
Curvy preload adjusters martin15s Stuff Wanted 0 23-06-10 04:44 PM
Curvy Preload Adjusters Stevetmanchester Stuff Wanted 0 14-05-08 08:28 AM
Fork preload adjusters on a curvy? Berlin SV Talk, Tuning & Tweaking 12 06-09-07 08:00 AM
