Old 26-06-13, 08:19 PM   #1
dirtyred619
Default Anybody used/use Danmoto rear sets?
Thinking of treating myself for my upcoming birthday and these seem a good product being pleasing on the eye and economically priced at about £100 delivered.
I've got a Danmoto exhaust which I'm more than happy with so I'd anticipate these being a good buy but the one thing I'd like to check on before purchasing them is that the bumf on their website states that there is no brake return spring or any option to fit one. It goes on to state that you don't really need one and all will be fine without.
So should this be the case and/or is this the case with other rear sets? Anyone use them have an opinion on them?
Mike
Old 26-06-13, 08:26 PM   #2
Runako
Default Re: Anybody used/use Danmoto rear sets?
Yep, they're good. The best thing I can say about them is I have't had to worry about them since fitting. You can also buy a brake light switch and fit easily enough (unless you are on of the exponents of "I never use the back brake anyway" )
Old 26-06-13, 08:37 PM   #3
dirtyred619
I do use it every now and then!
Good to get an early positive. About the brake switch, it says on the website that you can use the one already on the SV with these you just refit it.
Old 26-06-13, 08:48 PM   #4
LewSpeight
LewSpeight's Avatar
Good thread. I'll be keeping an eye on this cos I've been eyeing em up for abit
Sent from that magical device in my pocket.
Old 26-06-13, 08:49 PM   #5
Runako
Yep, correct for pointy (don't know about curvy) but I got a new one anyway as I needed to mod it a little. but its not a big deal either way.
Old 26-06-13, 08:56 PM   #6
leebex
you`ll need the rear brake switch for an mot surely?
I use a brake switch that uses brake fluid pressure, not the standard type as my rear sets have no provision for a switch.
Old 26-06-13, 08:57 PM   #7
dirtyred619
Right that's good. I'll just try and reuse the current switch if I can.
Have you got any pics of the rear sets fitted?
Old 26-06-13, 09:01 PM   #8
dirtyred619
It's the return spring. I think it's something to do with the pedal returning to its original position but I'm not positive about that hence the question. In there bumf on the website that the brake cylinder on the SV had a return spring built in that is sufficient for the job.
Old 26-06-13, 09:06 PM   #9
leebex
Ive got these fitted: http://www.gbmotoracingparts.com/gbm...1000-159-p.asp
with this switch: (might not be the exact thread pitch, but gives you an idea)
http://www.gbmotoracingparts.com/gbm...rset-310-p.asp
Lee
Old 27-06-13, 09:56 AM   #10
sniff
sniff's Avatar
Great rear sets. Only major thing is make sure you lock tight them in place. The bolts have a tendency of coming loose. Apart from that these are really worth the price.
sniff is offline   Reply With Quote
Rear sets? sloppy joe Bikes - Talk & Issues 4 29-05-10 01:52 AM
Rear Sets Davies 52 Stuff Wanted 0 18-04-10 07:02 PM
after market rear sets / rear break lights etuna SV Talk, Tuning & Tweaking 2 16-02-09 09:38 PM
Rear sets for K3 airbrush_assasin Stuff Wanted 0 10-09-08 10:30 AM
rear sets TSM SV Talk, Tuning & Tweaking 2 28-02-05 09:07 AM
