Old 29-06-13, 05:54 PM   #1
stranger12
Default SV650 lost some oil
Hellooo,
Bike: SV650S red 2005
I am struggling on how to check my engine oil.
while straight I did ask a friend to have a look at it and it was just above L . when sat on it, it did raise a bit above L. while on stand it was below L so confused over all
How do you guys check it , sat on it, on jack just raise it or how ?
They bike oil was full only about 1 month ago and seems strange to loose about maybe 500ml or more. it has dropped from F to just above L.
no blue smoke nothing so not sure how it has burned it . they engine revs perfectly and I infact rev it hard and it never complains.
what do you think could have caused the oil to drop below F?
as always many thank for all inputs
Old 29-06-13, 06:59 PM   #2
Fallout
Fallout's Avatar
Default Re: SV650 lost some oil
I always check my oil on a paddock stand when it's cold. You can't see it properly if you check it while you're sat on it. You need to look at the sight glass from the side, otherwise the lines will be out, plus you'll probably lean the bike a bit when you look at it. So really you need to get yourself an auxiliary stand, or if you're brave, lean it against a wall, or always get a mate round to help you. (Easiest to get a stand).
How many miles have you done in that month? I doubt F to L is 500ml. I never measured with my SV, but my gixxer is 300ml F to L.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 29-06-13, 07:47 PM   #3
i use an axle stand set at the hight so when the right foot peg bracket (same side as sight glass) is resting on it the bike is straight up and down. then i just gently lower it onto the side stand again. you could use a bit of wood or anything as long as its at the right hight.
Old 29-06-13, 10:17 PM   #4
Tomor
Tomor's Avatar
A brick works quite well
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 30-06-13, 09:04 AM   #5
stranger12
so take it it is not possible to stand on it and test ? i can sit on it and ask someone to check but the level differs from when i just hold it and ask someone to look at it
what do you think the oil loss would have been for ?
Old 30-06-13, 09:37 AM   #6
Mauler
Mauler's Avatar
I can't comment on the oil loss apart from suggesting looking for leaks around the engine casing, but if you're on the bike your weight pushes the rear of the bike down which can affect the oil level in the viewing window.
Best to do it as the other guys have said; with the bike up on a stand or held upright by a wall/friend.
Mauler is offline   Reply With Quote
Old 30-06-13, 10:11 AM   #7
Fallout
Fallout's Avatar
All bikes use oil. If you tell us the total mileage of the bike and how many miles you've done since it went from F to L, we can speculate on if it's reasonable or not.
Old 01-07-13, 09:55 AM   #8
ChrisCurvyS
ChrisCurvyS's Avatar
If you've not got a paddock stand, it's pretty easy to hold the bike from the right hand side and find the point where it's completely balanced - that's when you should be checking the oil.
It will always show a lower level if you tilt the bike to the left and a higher level when tilted to the right, hence falling below L when you put it on the sidestand.
I always find the difficult bit is seeing through the sight glass - bright sunlight or a torch helps.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 01-07-13, 10:32 AM   #9
Biker Biggles
Biker Biggles's Avatar
Or not having those useless fairings that get in the way
Old 11-07-13, 12:03 PM   #10
stranger12
it did lost 250 ml after around 1 month or 1000 milesh, has this happened to you guys?
lost keys to my k3 sv650, what to do? corsa120 Bikes - Talk & Issues 5 05-06-12 09:13 PM
Is lost... Grinch Idle Banter 33 22-10-09 04:05 PM
Lost Electrical Power SV650 99 philbert SV Talk, Tuning & Tweaking 4 26-05-09 12:15 PM
I must be lost... _Stretchie_ Soho Massive 18 24-05-07 02:53 PM
