Old 04-07-13, 11:57 PM   #1
LewSpeight
LewSpeight's Avatar
Default Folding clutch lever didn't fold, just snapped
Hi organs
Quick question, I dropped my bike the other day (accident getting it outof the garage, I know I know) and it snapped the clutch lever which is one of these flippy uppy ones that fold up instead of 'snapping'..
I've had it all of about 2 weeks this lever, would you email the seller and explain it didn't do its job properly? Or take the hit and buy a new set?
Sent from that magical device in my pocket.
Old 05-07-13, 04:52 AM   #2
Mauler
Mauler's Avatar
Default Re: Folding clutch lever didn't fold, just snapped
I'd say that if the lever is designed to fold up on impact instead of snapping then it's not done it's job - drop the guy a message?
Mauler is offline   Reply With Quote
Old 05-07-13, 07:35 AM   #3
The lever has a pivot that allows it to fold in one plane only - parallel to the pivot - if it is flexed in that plane all well and good.
Clearly the lever cannot fold in the plane that is required to operate the clutch - perpendicular to the pivot - if it is it may well break.
There is no guarantee that it will not break, that's not what the lever is about - the joint is only able to cope with certain deflections which increases the chances of surviving a drop, but makes no certainty.
I cannot imagine a way in which the lever could be constructed such that it could not be broken by dropping it, and certainly not if it is to function in any meaningful way as a clutch lever.
The fact that it broke does not mean there is a deficiency in the lever - you've just been unlucky.
Old 05-07-13, 08:51 AM   #4
LewSpeight
LewSpeight's Avatar
Cheers for the replies, I think I'll just take the hit and get a new one!
Old 05-07-13, 04:09 PM   #5
Teejayexc
Just wait for one to come up on sale here, then put a higher bid in
Old 05-07-13, 04:12 PM   #6
LewSpeight
LewSpeight's Avatar
Hahaha ooooooh low blow
FS: Blue adjustable folding brake and clutch levers LewSpeight For Sale - SV's and SV related items 8 08-06-13 11:40 AM
Snapped clutch lever perch bolt. hongman SV Talk, Tuning & Tweaking 6 02-08-10 09:04 AM
Gear Lever - Folding type - Curvy Lucas For Sale - SV's and SV related items 9 26-08-09 09:03 PM
Just snapped my brake lever - with my hand DarrenSV650S Bikes - Talk & Issues 15 09-05-09 05:45 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
