Old 05-07-13, 10:31 PM   #1
Daniel Louis
Default Which alternative shock? Pointy.
Hi Guys,
I've read some things about replacing the rear shock on my 2012 pointy.
What is a good option? I don't want to spend too much, but I have heard it's a good upgrade. My front end is standard and probably will remain so.
Thanks
Dan
Old 06-07-13, 08:22 AM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: Rear Shock
Changing the front gives a better improvement than changing a new standard rear shock unless you weight significantly more than average or always take pillions.
PS Define 'good upgrade' what are you after?
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 06-07-13, 10:22 AM   #3
Nutsinatin
Nutsinatin's Avatar
Get your front forks rebuilt first, it'll make much more difference and if you up the preload on the rear with improved forks it's not so bad, but if you're after a cheap rear shock upgrade the easiest (no cutting) is from a 2007 Kawasaki ZX10 which should cost £60/70 if you do it yourself, although if you put your weight and riding style up there will be much more knowledgeable guys on here to help you!
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 06-07-13, 01:11 PM   #4
what do you weigh?
how do you ride?
how many miles are on your bike?
Rear shock schoff43 Mini-Twins 3 04-03-13 01:53 PM
K3 Rear Shock DarrenSV650S For Sale - SV's and SV related items 1 15-06-08 02:58 PM
Rear shock 03-08 silent11 For Sale - SV's and SV related items 0 17-05-08 02:53 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
what rear shock robertpog SV Talk, Tuning & Tweaking 2 16-02-05 03:38 PM
