Old 08-07-13, 06:46 PM   #1
JohnStMartin
Default Hel brake lines , 2009 pointy, bit of advice please.
I replaced my ( tatty) brake lines with a hel kit , but the banjo bolt that goes into the brake lever doesn't quite seem to match the thread, its visually identical to the one i took out (although longer because R and L brake lines run from it).... any ideas?
edit: all the other bolts in the kit were prefect fitment.
also, have i ruined my brakes by replacing the original one line with a fork at the mudguard with this two lines all the way kit?
Old 08-07-13, 06:54 PM   #2
Mr wilson
Default Re: Hel brake lines , 2009 pointy, bit of advice please.
Two different thread pitches available on banjo bolts, 1.25mm and 1.5mm. That'll be where your problem is.
Supposed to give better braking with the double line set up, not sure if I noticed any difference when I did it, but shouldn't be any worse.
Shug
Old 08-07-13, 09:29 PM   #3
JohnStMartin
went back to it tonight in it went straight in.... strange.
mods close please
Old 08-07-13, 09:49 PM   #4
Nutsinatin
Nutsinatin's Avatar
Braided lines are less flexible, it's a pain to get the bolt to line up! Learnt that one!
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 08-07-13, 09:50 PM   #5
jambo
jambo's Avatar
Sometimes when fitting braided brake lines the force of he brake lines trying to twist slightly to line up can catch on the threads or make it difficult to get the banjo in straight. I suspect it was just no going in quite straight and is now fine.
Whether you use a 2 or 3 line set up is mostly a case of money, and aesthetics. There would be very little meaningful difference in fluid capacity or line flex in the systems
Jambo
Old 01-12-13, 12:24 PM   #6
disco
Thx to johnstmartin for the comment about the longer thread because both lines go into it. I can now fit my own hel lines.
Pointy OEM front Brake lines kit sopeluk For Sale - SV's and SV related items 0 04-03-13 06:03 PM
Wanted pointy rear undertray or tail tidy, braided brake lines, wavy brake discs. Chris*2700 Stuff Wanted 3 07-10-12 11:25 AM
Advice please! brake lines. BBadger Hardware 7 25-10-08 12:00 PM
hel brake lines, pics and advice? maff SV Talk, Tuning & Tweaking 38 24-09-08 09:52 PM
Stainless Braided Brake Lines (Pointy) svdemon Stuff Wanted 2 15-07-08 09:13 PM
