Old 09-07-13, 12:28 PM   #1
baldricc
Default Cable lengths; naked v faired?
Can any one tell me the difference in throttle cable lengths between the sk3 and k3. Thanks
Old 09-07-13, 12:57 PM   #2
Default Re: cable lengths
you cant change the cables from the naked to the sport. but as far as i'm led to believe the V-Strom cables should work. or you could try and get the full throttle assembly from the v-strom
Old 09-07-13, 01:19 PM   #3
baldricc
Cheers for that found DL cable but can't find throttle tube or housing yet. But thanks again
Old 09-07-13, 03:12 PM   #4
punkyp
Default Re: Cable lengths; naked v faired?
DL throttle cables will work, although very long, you will need the housing, as I mentioned last night.
Try http://www.ebay.co.uk/itm/SUZUKI-DL-...item1e6f04c6e3
Get the clutch cable while you are at it.
Also, apparently you can change the N cables on to the S, but you will need the whole right hand switch gear.
Old 09-07-13, 03:56 PM   #5
baldricc
As I said struggling with dl tube but just spoken with venhill and £45 + vat to extend. But bandit mania said new sv1000 already extended about £50. But some one has just said zx10r uses same throttle cable as dl so looking into that at moment.or if any1 has a bust throttle cable cheap
Old 10-07-13, 07:29 AM   #6
punkyp
I'd sell you just the cables, but I think I'd have better luck selling as a whole, unless anyone wants the yoke, bars and brake lines separate.
Clutch and throttle cable lengths? Svrider88 SV Talk, Tuning & Tweaking 2 23-03-11 08:57 PM
Cable lengths. Stig SV Talk, Tuning & Tweaking 0 16-01-08 08:56 AM
naked , part faired, fully faired jans1971 Bikes - Talk & Issues 11 18-11-07 02:53 PM
CLUTCH CABLE. FAIRED v NAKED(99-2002) 21QUEST SV Talk, Tuning & Tweaking 4 13-04-05 01:33 PM
