Old 10-07-13, 11:24 AM   #1
SUPERSTARDJ01
Default Waterproof/shockproof Galaxy s2 motorcycle case
ultimate addons galaxy s2 case which is waterproof, dust proof and shckproof with handlebar clamp.
£10
Old 10-07-13, 11:32 AM   #2
Littlepeahead
Littlepeahead's Avatar
Default Re: Waterproof/shockproof Galaxy s2 motorcycle case
Maybe interested - you got a photo? I will try Google too.
Old 10-07-13, 11:58 AM   #3
Nobbylad
Nobbylad's Avatar
Doubtful I know, but if this would fit an S3 - I'd take it.
Old 10-07-13, 12:03 PM   #4
muzikill
muzikill's Avatar
Ill take it.
Old 10-07-13, 03:35 PM   #5
SUPERSTARDJ01
s2 only I'm affraid, I'll post a pic soon, there's a rubber gromit that sits at the bottom to plug a hole for a hardwire charger to fit I'll check I still have that I'm sure it's in the case and if so Muzikill it's yours.
Old 11-07-13, 02:04 AM   #6
muzikill
muzikill's Avatar
Default Re: Re: Waterproof/shockproof Galaxy s2 motorcycle case
Ta ... let me know payment info.
Old 11-07-13, 10:43 AM   #7
punkyp
2nd Dibs
Old 14-07-13, 09:07 PM   #8
muzikill
muzikill's Avatar
Details to send payment etc....?
Old 16-07-13, 10:50 AM   #9
SUPERSTARDJ01
I can't find the little rubber grommit it's the thickness of the charging cable, if you have the bike charger then it wont matter.
Old 16-07-13, 10:51 AM   #10
punkyp
I'll take it without, if muzikill passes on it.
Motorcycle 12v Waterproof Socket & Wiring N77 For Sale - SV's and SV related items 8 18-05-12 05:11 PM
Sat Nav Waterproof case and Handle Bar Mount N77 For Sale - SV's and SV related items 5 19-04-12 07:17 PM
satnav waterproof case / mount steveg Bikes - Talk & Issues 23 11-07-10 10:30 AM
size 9 brand new waterproof motorcycle boots markmoto For Sale - SV's and SV related items 4 10-11-07 07:47 PM
RST VORTEX WATERPROOF MOTORCYCLE BOOTS Stig Boots 4 10-01-07 12:20 AM
