Old 11-07-13, 07:24 PM   #1
JohnStMartin
Default New pads won't fit in caliper.
Rear Brake:
Put my new pads in. pistons are pushed in as far as they will go. I have double checked they are the correct pads. The pads wont fit around the disk, and the innermost (closest to the center of the wheel) seems loose.
What could cause these problems ?
Old 11-07-13, 07:33 PM   #2
Kwally5
Default Re: Quick pointy brake question.
Hmm,
I would definitely double check those pistons are fully in.
Are they not moving slightly out as you take pressure off the pistons?
Never heard of this problem before.
Kieran
Old 11-07-13, 07:53 PM   #3
there are 'keys' in the pads that sit in the carrier of the calliper.
Old 11-07-13, 07:55 PM   #4
Biker Biggles
Biker Biggles's Avatar
Are the pistons fully in?If not the new thicker pads may be too big.Try taking the lid off the fluid reservoir to take pressure off the system if you cant get the pads pistons in but be careful of spillage.Its possible you have topped up the fluid to compensate for pad wear over time and there may now be too much fluid.
Old 11-07-13, 10:12 PM   #5
JohnStMartin
the system is dry because i put HEL lines on.... I'm going to take them apart again tommorrow and have a look.
Quick Question foir pointy owners CLARKYsv SV Talk, Tuning & Tweaking 3 04-07-11 11:37 AM
Quick question; will a pointy lock set fit a curvy? Taipan SV Talk, Tuning & Tweaking 1 07-01-10 07:29 AM
Quick brake caliper question Needsy SV Talk, Tuning & Tweaking 8 18-03-08 08:38 PM
quick Pointy wiring loom question chunkytfg SV Talk, Tuning & Tweaking 1 07-02-08 07:36 PM
Quick question......rear brake reservoir svrash SV Talk, Tuning & Tweaking 0 22-02-06 10:36 PM
