Old 15-07-13, 01:10 PM   #1
JulesW
JulesW's Avatar
Default Suspension: Low cost upgrade?
SV 650S K6
Recently acquired a very tidy bog standard pointy and need to make a few mods to firm her up.
First job is to find a (very) cost effective way of sorting out the soggy front end. I'm reluctant to put a GSXR front end on her just in case I end up doing a few minitwin outings on her.
Money is tight so I'm looking for ideas that will provide a cheap way of sorting out the front end.
I'll probably do the rear shock at the same time if cash allows. I was thinking of putting a GSXR or ZX10 rear shock on instead of the standard one. Will either of these bolt straight on? Which (if any) would be most suitable. [ I weigh 10st 8lbs ]
Any suggestions gratefully received
JulesW is offline   Reply With Quote
Old 15-07-13, 01:12 PM   #2
Default Re: Suspension: Low cost upgrade?
For front stick some ktech springs and cheap emulators in.
Old 15-07-13, 01:17 PM   #3
Daffy_Duck
Great post JulesW I thinking exactly the same, im same weight to so if someone knws something about the rear shocks i think we'd both be greatfull
Old 15-07-13, 01:37 PM   #4
Pete7
Pete7's Avatar
I don't think you could do better than spending an evening reading this:
http://forums.sv650.org/showthread.p...highlight=zx10
Pete
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 15-07-13, 01:46 PM   #5
JulesW
JulesW's Avatar
Many thanks Pete
That should keep me out of mischief for an hour or two. Just the thread I was looking for. Never seem to get intelligent results from the search features on forums. Many thanks Pete
Old 15-07-13, 02:17 PM   #6
wideguy
Yes to this.
Proper rate springs and emulators will make the front end excellent. I'm just under 12 stone with gear, and the rear worked pretty well for me as it was for quite a few years. The cheap Penske I put on is better, but not the night/day result I got in the front with springs and emulators.
Old 15-07-13, 02:50 PM   #7
chris c
What are emulators?
Old 15-07-13, 02:57 PM   #8
Valves added on top of the damper rods to add some control over compression damping
Old 15-07-13, 05:35 PM   #9
Nutsinatin
Nutsinatin's Avatar
On the shock a ZX10 should bolt straight in if it's from a 2007 Kawasaki (you need a 55mm bolt and nut from Kawasaki), don't know if it's a bit to heavily sprung for you though - there is a fantastic spreadsheet list of rear shocks that I can't find atm (hopefully someone will link it!) but I'm not sure how many of them bolt in without any cutting. This is a great install guide for the ZX10 though, it's the one I used! http://www.svrider.com/forum/showthread.php?t=80387
Here is the spreadsheet (made by someone else, nothing to do with me, you might have to log into a google account to view it!) https://docs.google.com/spreadsheet/...COvG24gH#gid=1
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
suspension upgrade what to do? stew SV Talk, Tuning & Tweaking 10 19-03-11 05:31 PM
Suspension Upgrade makemdan SV Talk, Tuning & Tweaking 8 04-02-08 09:06 PM
Suspension Upgrade Cam_73 SV Ecosse 4 08-11-07 02:11 AM
Suspension Upgrade svdemon SV Talk, Tuning & Tweaking 3 18-08-07 02:15 PM
Suspension upgrade MattTheLoony SV Talk, Tuning & Tweaking 9 09-06-06 11:30 AM
