Old 15-07-13, 05:55 PM   #1
mills94
Default Replacement tachometer glass for Curvy naked?
hi all,
for some reason it seems my double bubble screen has magnified the heat and melted a line down the rev counter glass, what i want to know is wether or not i can replace just the glass on its own.
Old 15-07-13, 08:26 PM   #2
stuR
Default Re: replacing the rev counter glass?
Im sure ive seen this before and the consensus was no i think, have a search on here.
Old 15-07-13, 08:58 PM   #3
The 'glass' itself is not listed as a separate part, you can get:
Upper case 34150-19F20, £128.51 from Robinsons Foundry.
Which, as the name suggests, is both lenses and the top part of the clock case.
If it were my bike I'd have the clocks apart and see if I could get a bit of Perspex cut and glue it in place.
Old 15-07-13, 10:09 PM   #4
mills94
Default Re: Replacement tachometer glass for Curvy naked?
ok thanks for both of your input, to be fair its probably not worth replacing the whole lot for the sake of one lense, its me being picky i know but its annoying as there are no marks on the bike other than this now. in any case its not massively obvious but i know its there. pretty certain it would only happen again if i replaced them without reverting to the original screen so i suppose i may aswell leave it be, unless i could as sid squid suggests cut some perspex.
Naked K1 Speedo/Tacho Glass asembly wanted. ejohnh Stuff Wanted 1 13-02-13 05:20 PM
Speedo/Tacho glass for K1 naked. ejohnh Stuff Wanted 2 28-01-13 01:51 PM
Replacement mirror glass for Curvy? squirrel_hunter SV Talk, Tuning & Tweaking 3 20-01-13 08:12 PM
Replacement clocks for naked curvy? bikermike SV Talk, Tuning & Tweaking 1 26-09-12 10:25 AM
Replacement clocks for naked Curvy? bikermike SV Talk, Tuning & Tweaking 2 22-08-12 11:13 PM
