Old 17-07-13, 07:41 PM   #1
MickeyHall
Default Crashed my Pointy.
Ok so the k5 pointy ate the dirt today all is well it was a slow off, just a grazed handle bar a grazed front brake lever, a broken rear brake pedal and a broken mirror. Oh and the fairing is grazed but has been touched up with black tee cut and the exhaust is scratched!
Back brake pedal is being fixed Saturday at a cost of £80!!! How easy is it to do yourself. Is it illegal to ride without a rear brake, although I may have broken the law riding it home from London today if it is.
Mirrors are the indicator ones are they easy to instal? Or can the head be taken off and replaced? At the moment it is taped to the front of the bike so the indicator can still be seen.
Anything else I should check. I did notice this morning it was making a ticking sound when riding but I thought this was normal?.
not good for the confidence!!!
Old 17-07-13, 09:16 PM   #2
coopesh56
Default Crashed!!!
Unlucky mate.. No idea about the indicator mirrors. But if it helps I fixed my gear lever myself for free when I had my off. Drilled a bolt through the side of it as the bit your foot hooks under had sheared. I intended for it to only be a short term fix, but two years later I still use it as its just as good as the original! Not sure if you could do that to yor rear brake lever?
Coops
Old 17-07-13, 09:19 PM   #3
Default Re: Crashed!!!
How is the brake pedal being fixed? Speak to Davie on here about his fixer peg
http://www.fixer-peg.co.uk/
Old 17-07-13, 10:21 PM   #4
Mauler
Mauler's Avatar
Default Re: Crashed my Pointy.
On my lil' CBR125R I bent the rear brake pedal back out into position when I was knocked off. Seemed easy enough, I'm sure the SV will be similar, just a bit bigger so you may need a longer lever?
What's happened to the rear pedal?
Mauler is offline   Reply With Quote
Old 18-07-13, 12:00 PM   #5
ChrisCurvyS
ChrisCurvyS's Avatar
I've had one of Davie's fixer pegs on my back brake lever for about two years (given to me by an ex-orger). Still going strong and not been an issue for the MoT.
80 quid is a lot of money for a little piece of cheap metal.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 18-07-13, 12:14 PM   #6
Xpistos
If you don't want to go to fixer peg route, just buy one off ebay and change it your self, its not hard to do and I found a new pedal for £27 with postage
Old 18-07-13, 09:20 PM   #7
MickeyHall
It sheered Off the knob part, going to the garage for it to be done by the pros. The mirrors won't be here till August so the broken one is taped to the front so it can show an indication, is this an mot failure?.
Also the bike is making a ticking noise when the engine runs, and accelerates, is this normal?
Old 18-07-13, 10:17 PM   #8
Red ones
Red ones's Avatar
Did he just say he tore his knob off and is now getting it fixed by pros?
Ooer..
Old 19-07-13, 09:01 AM   #9
Stooks
Just drill the lever and put a bolt in. I know loads of people that have done that. The indicator mirrors just make sure you follow the wiring as the snapped off one and you'll be fine
Stooks is offline   Reply With Quote
Old 01-08-13, 09:22 PM   #10
MickeyHall
Got my knob fixed and my mirror, she just has some battle scars to contend with now but makes her look hard
Crashed! Frenchi SV Talk, Tuning & Tweaking 2 25-09-11 10:06 PM
Crashed. barwel1992 Bikes - Talk & Issues 77 10-12-09 11:37 AM
My day (I crashed a little bit!) chakraist Bikes - Talk & Issues 50 23-10-08 10:30 PM
Crashed heros Bikes - Talk & Issues 15 23-02-07 04:10 PM
crashed in to!!! goldengraemes SV Talk, Tuning & Tweaking 50 11-04-05 12:57 PM
