Old 18-07-13, 07:49 AM   #1
Bikerste
Default Horn not working properly.
My horn on the bike is very low, when I press the horn switch the clocks dim and a faint noise from the horn, all fuse's are ok, any advice or help please.
Old 18-07-13, 07:51 AM   #2
Pete7
Pete7's Avatar
Default Re: Horn on Sv650 help please
Probably high resistance from a corroded connection or a stuffed horn.
Pete
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 18-07-13, 07:59 AM   #3
Mauler
Mauler's Avatar
Battery?
Mauler is offline   Reply With Quote
Old 18-07-13, 10:01 AM   #4
timwilky
timwilky's Avatar
Definitely the R/R, one from a honda should fix it.
SV horns are a consumable. I replaced mine years ago with a 10 quid loud plastic device from the local car shop.
You need to get the right one though. cheap earth return is no good on the SV.
Not Grumpy, opinionated.
Old 18-07-13, 11:28 AM   #5
Look at the back of the horn, you'll see a screw locked with a dab of paint/lacquer. This is the adjuster.
Commonly if the horn makes a click and uses lots of current, (this evidenced by the lights dimming), the points aren't separating - back the screw out a bit.
The reverse is also true: If the horn makes no noise, (or if you back the screw too far), the points aren't closing - turn the screw in a bit.
If the supply is ascertained as good but the horn does nothing; no noise or clicks, then there are faults that adjustment may not cure - the coil may have failed or the points may be corroded. Usually however if it makes a click then clearly this demonstrates the coil and points are continuous - adjustment may well cure the problem.
Old 18-07-13, 11:37 AM   #6
Shawthing
Shawthing's Avatar
Default Re: Horn not working properly.
Too much heat from the radiator ( especialy in these weather conditions) can affect the std horn's performance. Check it out both Hot and Cold.
SK9 Sport Black Delkevic can.
horn not working tommo891 SV Talk, Tuning & Tweaking 21 26-11-12 09:47 PM
Indicators not working properly. 999birdie SV Talk, Tuning & Tweaking 3 15-10-10 05:19 PM
K5 Horn not working hindle8907 Bikes - Talk & Issues 9 06-02-10 10:01 PM
Horn not working. SAMMY650 SV Talk, Tuning & Tweaking 7 13-05-08 08:26 PM
Air horn not working. therealvw Bikes - Talk & Issues 4 24-07-07 07:25 AM
