Old 19-07-13, 03:23 PM   #1
ChrisCurvyS
ChrisCurvyS's Avatar
Default Which bit of clutch needs replacing?
For over a year now I've had to constantly re-adjust my clutch to keep it from dragging and have had to keep the adjuster at the lever turned our precariously far to the right in order to get enough purchase to change gear smoothly.
Seems to be related to a clear visual fault with the lifter thingy (possibly made worse by a larger front sprocket) - here's a previous thread with valuable as ever input from Sid Squid:
http://forums.sv650.org/showthread.p...ghlight=mortal
After putting off replacing the lifter machanism for so long, I've now got to the stage where the adjuster behind the sprocket cover is up as far as it can go and I've also had to pull the cable out a bit from the frame to keep it changing gear and finding neutral, so I know the game's up.
My question is: will I also need to replace the clutch plates or any other bits too? The clutch hasn't been slipping (apart from when I've adjusted it badly) but my Curvy has done about 45k now so may well need one sooner or later anyway.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 19-07-13, 04:57 PM   #2
Murley.
Default Re: Which bit of clutch needs replacing?
What's the worm gear like on the clutch mechanism (the bit behind the sprocket cover) as if there is a lot of slop in due to wear or missing bearings, it make disengaging the clutch require more cable pull. My curvy is on 67,000 miles with the original clutch and lots of adjustment left so it seems it's just an adjustment issue on yours.
Old 19-07-13, 05:46 PM   #3
Red ones
Red ones's Avatar
Sound like the clutch adjuster mechanism aka worm gear. They are made of finest soft cheese. It's a 20 minute job to do and a new one costs about £45. Mine packed in at about 65,000 miles but only recently replaced it - wished I did it sooner.
I'd do that then reassess the issue .
Old 19-07-13, 11:26 PM   #4
If it doesn't slip the clutch itself is probably OK. As it drags, the lifter probably isn't.
Old 22-07-13, 09:44 AM   #5
ChrisCurvyS
Thanks for the responses chaps - Murley, if the worm gear is the bit around the adjustment nut/screw, then it's fecked. The three-pronged thing popped out ages ago and sits much further forward than it should do - as you say it's needed more and more cable pull (to the point where I've actually pulled the cable out the side of the bike!) to make it work.
Red ones - does the clutch adjuster machanism come as one single unit? Obviously I'll replace the cable at the same time too.
Old 22-07-13, 09:59 AM   #6
jambo
jambo's Avatar
The clutch lifter is all one unit, around £45.
Item #17 on this fiche: Suzuki part #23200-11D00 for the 99-02 SV650
Jambo
Old 22-07-13, 11:39 AM   #7
ChrisCurvyS
many thanks jambo - sorry wasn't being lazy, just wasn't sure what the correct term was. Will get that ordered and see if it sorts it.
Old 07-09-13, 09:03 AM   #8
ChrisCurvyS
Finally getting round to sorting this. Quick question - will the lifter/actuator from a pointy fit a curvy? That Robinsons Foundry is obviously listed as up to 02 only but they look identical.
If so, this looks good value:
http://www.ebay.co.uk/itm/SUZUKI-SV6...item1e7ea05738
Old 07-09-13, 09:07 AM   #9
Yeah same part
Old 07-09-13, 09:13 AM   #10
ChrisCurvyS
Cheers Chris.
Would normally be wary of getting it from a breakers to save £20 but it looks a good one and would take longer to get one from Robinsons. Want to get back in the saddle asap, sick of sitting in fecking traffic jams.
Clutch drag? Wheel spins when clutch pulled in. frankie77 SV Talk, Tuning & Tweaking 6 02-06-12 06:46 PM
replacing clutch and front brake lever. musne SV Talk, Tuning & Tweaking 3 07-01-12 03:26 PM
Replacing Clutch - which tools needed? bengodden SV Talk, Tuning & Tweaking 1 01-02-11 12:56 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Replacing The Clutch Plates Mesomorphman SV Talk, Tuning & Tweaking 28 10-09-06 11:28 PM
