Old 20-07-13, 04:03 PM   #1
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default FAO Monkey (or anyone wanting to do some smoking)
Here you go fella, quick guide on using your BBQ to do some smoking.
https://www.dropbox.com/s/30vj2opxx9...your%20BBQ.pdf
And this is just for you too:
- Cooked for two hours
- Removed from smoker, wrapped in foil and returned to smoker to cook for two more hours
- Remove from smoker, unwrap (this is the stage I took this pic), then smother in BBQ sauce and bit more rub then back on the smoker for another hour to firm up
How to amuze an idiot:
Look right-> <-Look Left
Old 20-07-13, 05:34 PM   #2
Pete7
Pete7's Avatar
Default Re: FAO Monkey (or anyone wanting to do some smoking)
Some good tips in the article because its always a disaster when we try a BBQ.
Pete
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 20-07-13, 06:37 PM   #3
Tom_the_great
Tom_the_great's Avatar
I cant cook and dont have a bbq but I want them !!!
Tom! Cleaned more then ridden ! SV650S 10 Plate Pointy!!,
Black Tinted Screen!, Evotech Tail Tidy!, OEM Rear Hugger!, R&G Crash Bungs!, Delkevic Exhuast!
Current Mileage = 3000 (Ish)
Tom_the_great is offline   Reply With Quote
Old 21-07-13, 03:13 PM   #4
_Stretchie_
Large Member
They were good, taken off the grill after 5 hours cooking at 17:30, wrapped in foil, put in a cool box at and taken down to Vipers house for a little get together. They were not Taken out of cool box until about 19:30, still hot got chopped up and they were polished off within minutes.
I'm a happy bunny
Old 22-07-13, 12:11 AM   #5
chris8886
chris8886's Avatar
I'm not quite sure how much monkey gets on the forum atm, so you might have to FB him a link to show him this.
does look good too, might I add!
AR08 to AR13-QUALITY!
Old 22-07-13, 09:21 AM   #6
jambo
jambo's Avatar
I just don't think I spend enough time with Stretchie, I should visit him for a week or 3.
Jambo
Old 22-07-13, 12:50 PM   #7
_Stretchie_
Large Member
Jambo I agree :X
You are all welcome (for a nominal 'voluntary' donation)
Old 22-07-13, 01:09 PM   #8
Nobbylad
Nobbylad's Avatar
Thanks for the pdf Stretchie....I'm deffo gonna give this a go. What other joints do you tend to cook in there? I seem to remember brisket being on the menu, also, do you have any good rub recipes?
Old 22-07-13, 02:18 PM   #9
flymo
flymo's Avatar
can also use for Mackerel. I came back from Anglesey on Thursday after catching 150 fish!
Old 24-07-13, 01:01 PM   #10
_Stretchie_
Large Member
You could use multi layered cake drying racks on top of each other to do several fishes BUT it depends what you want to do with them. The approach in the doc will cook them (a rainbow trout for instance with two slices of lemon in the middle and laid on top of a piece of foil {NOT WRAPPED IN IT} on the grill takes about 45 mins if hot smoked and tastes GREAT), if you want to smoke to preserve and/or add flavour then you want to cold smoke it and for that you don't want the temp very high, probably not past 10c (awaits someone more knowledgeable).
To cold smoke just replace the coals with your cold smoke generator (or whatever you use) but you can then put the smoke in the middle of the BBQ base not on one side like in the doc and you can then use all of the food grill for whatever you are cold smoking, cheese, garlic, raw bacon, kippers.
The only thing I would say for cold smoking this way is to do it in a shed or something sheltered and out of direct sunlight as the direct sunlight (especially at the moment) can get the inside of your BBQ hot, currently during the day my smoker can be about 50c just sat there with no fuel in it thanks to the sun and this would ruin your cold smoking efforts as it would start to cook the food and the higher temperature could then make it a breeding ground for bacteria that will make you unwell and we don't want that do we kids.
