Does anyone make or know where to purchase the Switchable TRE lead? found them on another forum but its not in the UK on US forum there $40?
And do they make a massive difference? Cheers Mark |
Why do you want to switch it? Just disconnect the wire, although I don't think it makes enough of a difference having done it a long time ago.
From memory the timing retard eliminator makes very little difference on the sv. I seem to remember you could do the same mod by cutting a wire so it's not a particularly complex box
![]() Jambo Sent from my thingie
Total Retard Entrapment. you'll get better results setting the TPS. the SV does not produce enough horses to make a difference.
Bike in the avatar is a Pointy. TRE works differently on a Pointy - disconnecting wires isn't how it's done.
Saying it doesn't work is to not understand what it does, how or why. There can be a positive effect, but there are downsides, hence why most people who actually understand anything about it make a small plug in loom with a switchable TRE - hence wanting the plugs. Search SV Portal for a plug supplier.
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 21-07-13 at 08:33 PM. |
Thought this was more relevant to SV Talk, rather than stuff wanted so have moved it.
Switchable TRE going for SV1000 (or 650 if you want to change the connectors) | monkey | For Sale - SV's and SV related items | 8 | 10-02-10 10:13 AM |
Are NGK Iridium Sparks Plugs better than standard plugs? | Cartlidge | SV Talk, Tuning & Tweaking | 12 | 04-09-09 06:45 PM |
Ear plugs | ArtyLady | Helmets | 10 | 29-05-08 10:22 PM |
EAR PLUGs !!!!! ehh?? | vsumouse | Ancillaries | 14 | 11-05-06 03:59 PM |
Ear plugs | Kate | Bikes - Talk & Issues | 23 | 22-11-05 09:17 PM |
